Tedious
Plenty of good writeups in the "How to" section.
This is a tedious process that has many steps.
My only real hints are...
Get a couple of those magnetic trays..one for each side.
Remove both front seats...4 bolts each and makes life a lot easier.
Disconnect the speedo cable at the transmission so you can slide out the instrument cluster.
A flexible 1/4 extension is your friend for those screws near the windshield.
Nutdrivers and torx screwdrivers are great.
AS you take stuff apart, take a moment to learn how it will be put back.
This is helpful due to the sheer volumne of nuts, screws, actuators, plugs, clips, hoses, and routing of these items.
Bruce
