Hi all, new to the forum. My skill level has been up to replacing brakes, underdrive pully, rear sway bar, fuel filter and the usual maintenance things like spark plugs and oil changes. Does anyone know what happened to teamzx2.com? It was only about 2 years ago I received a birthday greeting from them.
Anyway, to the point. My clutch just started sticking where the pedal will intermittently go to the floor but the clutch remains engaged. Luckily I wasn't too far from home when it started. I topped off the brake fluid reservoir. I looked it up on youtube
and it doesn't seem like too difficult a fix. Has anyone had experience with this and anything I should know?
Two more questions. I am concerned about bleeding the air out of the line when everything is replaced. Is there anything to be aware of?
Finally, I usually order from Rockauto.com. Does anyone know what brand is the most reliable to go with?
Thanks
Thanks
