1 - 4 of 4 Posts
hi, can anyone help me, ii`m having trouble trying to wire up the cl motors, i can`t run the wiring from the door into the car because my escort uses a multi plug attachment for the existing wiring, i would rather not drill new holes. can anyone please help will be very much appreciated
What are central locking motors?
If you need to go through the firewall, you don't have to drill. There is a rubber grommet surrounding the big wire cluster where it runs through the firewall under the passenger's feet carpet. Just take a razorblade and poke a slit in that rubber surrounding the wirepack. Run a wire through there. I still don't know what a cl motor is... so this may not be any help at all...
a central locking motor is a power door lock, but you don't have a button for it in the car. Lets say, you press your lock, all the other locks will lock and vice versa for unlocking. Or if you use your key on the outside all the doors will unlock. I bought a set like that just haven't installed it yet
1 - 4 of 4 Posts
