1 - 13 of 13 Posts
Hey Everyone.
I was driving around my '97lx this past week, and my CEL came on. I took it over to the parts store to get the code pulled, and it came back with a "Catalyst efficiency below minimum tolerances (bank 1)". I then had them clear the code to turn off the light.
I havent had the light come back on, but I havent driven that many miles yet. Im just wondering if this means my cat is now shot, or if I need to just change out my O2 sensor(s). Has anyone dealt with this code before? The car still seems to be running fine, I just want to know if I need to start thinking about a new cat sometime soon.
Thanks in advance.
~Bug
I have a 2nd gen LX, so I don't even have that code. I'm not sure how much this will help, but here are a few possibilities in the order I'd suspect:
1. The sensor that throws the code is developing a short (catalytic converters are made to be extremely reliable so people aren't tempted to remove them at the first sign of trouble). Also, your catalyst should never wear out.
2. You may be running just a shade rich so that the molecular surfaces of your catalyst have fouled, particularly just after start-up before the engine is fully warm. Not enough to bring in a rich code, but enough to slowly degrade the usefulness of your catalyst.
3. The housing of your catalytic converter has a whole or flaw in it somehere allowing air and moisture in.
I can't imagine that your exhaust O2 sensor is at fault, even though I've had problems with two of mine. I'm assuming you have an additional sensor in your 97 that is downstream of the cat.
Sorry I can't offer much more than that.
Thanks for the quick reply.
I didnt think my catalyst should run out, so I was a little curious. A few months ago I was having some trouble with a misfiring cylinder, so I do suppose that could have something to do with it. Ill keep driving it around and see if the code decides to come back on again.....
Thanks again!
~Bug
What's the code number? Generally speaking, they aren't Escort specific and you should be able to browse the newsgroups and get an answer.
Good suggestion.
I had a few minutes so, I looked around this site, because I remember someone posted a whole whack of codes once.
In the ENGINE TUNING forum, in a post titled, "I'm new here and I need help figuring out this code" KCZX2 asked a question about codes (posted Nov 23, 2003). Purple_gt responded with a dump of ten million codes.
The code message you provided does not exist on this list, but there are a few that are close, namely P0420, P0421, P0422 and P0423. I would guess that the code you received was P0420, but that's just a guess.
I'm curious about this, because I've never seen any catalyst codes before, so I'll snoop around and get back to you if I find anything.
Ok, I spent 15 minutes looking into this. Without knowing the 3rd gen at all, I'm sure the code you received was P0420. Check out the following link, about half way down the article, under Part D Catalyst Efficiency Monitor
http://www.v8sho.com/SHO/TSB0197HO2SServiceTips.htm
You must have an second exhaust O2 sensor downstream of the cat, as suspected. The signal from it, combined with the signal of the exhaust O2 sensor upstream of the cat combine to determine efficiency. For the condition you described, the downstream O2 sensor signal was coming in more frequently than expected, so it brought in your CEL and the referenced trouble code. There's a bunch of possible causes listed in the article.
In your second entry, you mentioned you had a misfiring cylinder. That would do it. Do you still have problems with that cylinder? Are you burning any oil (ie through that cylinder)? There's a chance your downstream O2 sensor is on the way out, as guessed earlier, but this seems much less likely knowing you had a misfire condition.
Thanks for all the input everyone, I very much appreciate it.
I didnt actually get the code itself, but I can get it again next time I go to the garage (the CEL came on again today) Checking into that page that you linked to, I do believe that you have picked the correct code, the P0420. I really appreciate you looking around for me to help me figure this thing out...
In regards to the cylinder misfire, that problem is all taken care of (as far as I know....) I actually had a bad spark plug wire that was causing the problem under load, and eventually at idle as well. I replaced the spark plugs, the air filter, and the wires in order to solve that problem. However, before hand I did run several different fuel additives through the system, thinking that could have been the problem.
So, Im honestly hoping that it is an 02 sensor as opposed to my catalytic converter on the fritz..... I do know that I need a new muffler sometime in the near future, but I dont know if this would cause the problem or not. I do have 120k on the car, so perhaps the sensor(s) have conked out.
I really dont feel like having to replace my cat if that is in fact the problem...
Thanks again for helping me out with this!!
~Bug
Discussion Starter · #9 ·
I have only owned the car for about a year and a half so far, and I bought it with 101k (miles) on it. I havent changed out the O2 sensors ever, but I have replaced just about all of the other tune up items, I think.
I picked this up it might help
OBD-II scanner manual and what have you...
P0700 Transmission Control System (MIL Request)
P0703 Brake Switch B Input Circuit
P0704 Clutch Switch Input Circuit
P0705 Transmission Range Sensor Circuit (PRNDL Input) *
P0707 Transmission Range Sensor Circuit Low Input *
P0708 Transmission Range Sensor Circuit High Input *
P0712 Transmission Fluid Temperature Sensor Circuit Low Input ^
P0713 Transmission Fluid Temperature Sensor Circuit High Input ^
P0715 Turbine Shaft Speed Sensor Circuit *
P0717 Turbine Shaft Speed Sensor Circuit No Signal
P0718 Turbine Shaft Speed Sensor Circuit Intermittent ^
P0720 Output Shaft Speed Sensor Circuit *
P0721 Output Shaft Speed Sensor Circuit Range/Performance ^
P0722 Output Shaft Speed Sensor Circuit No Signal
P0723 Output Shaft Speed Sensor Circuit Intermittent
P0731 Gear 1 Incorrect Ratio ^
P0732 Gear 2 Incorrect Ratio ^
P0733 Gear 3 Incorrect Ratio ^
P0734 Gear 4 Incorrect Ratio ^
P0735 Gear 5 Incorrect Ratio ^
P0741 Torque Converter Clutch Solenoid Circuit Performance Or Stuck Off ^
P0743 Torque Converter Clutch Solenoid Circuit Electrical *
P0745 Pressure Control Solenoid A *
P0746 Pressure Control Solenoid A Performance or Stuck Off *
P0750 Shift Solenoid A *
P0751 Shift Solenoid A Performance or Stuck Off *
P0755 Shift Solenoid B *
P0756 Shift Solenoid B Performance or Stuck Off *
P0760 Shift Solenoid C *
P0761 Shift Solenoid C Performance or Stuck Off *
P0765 Shift Solenoid D *
P0766 Shift Solenoid D Performance or Stuck Off *
P0770 Shift Solenoid E *
P0771 Shift Solenoid E Performance or Stuck Off *
P0775 Pressure Control Solenoid B *
P0779 Pressure Control Solenoid B Intermittent
P0781 1-2 Shift ^
P0782 2-3 Shift ^
P0783 3-4 Shift ^
P0791 Intermediate Shaft Speed Sensor Circuit
P0794 Intermediate Shaft Speed Sensor Circuit Intermittent ^
P0795 Pressure Control Solenoid C *
P0796 Pressure Control Solenoid C Performance or Stuck Off *
P0797 Pressure Control Solenoid C Stuck On *
P0799 Pressure Control Solenoid C Intermittent
P0812 Reverse Input Circuit
P0814 Transmission Range Display Circuit
P0815 Upshift Switch Circuit
P0816 Downshift Switch Circuit
P0818 Driveline Disconnect Switch Input Circuit
P0840 Transmission Fluid Pressure Sensor/Switch A Circuit
P0844 Transmission Fluid Pressure Sensor/Switch A Circuit Intermittent
P1000 OBD Systems Readiness Test Not Complete
P1001 KOER Not Able to Complete, KOER Aborted
P1100 Mass Air Flow Sensor Circuit Intermittent
P1101 Mass Air Flow Sensor Out Of Self Test Range
P1109 Intake Air Temperature B Circuit Intermittent
P1112 Intake Air Temperature Circuit Intermittent
P1114 Intake Air Temperature B Circuit Low Input (Super/Turbo Charged engines) *
P1115 Intake Air Temperature B Circuit High Input (Super/Turbo Charged engines) *
P1116 Engine Coolant Temperature Sensor Out Of Self Test Range
P1117 Engine Coolant Temperature Sensor Circuit Intermittent
P1120 Throttle Position Sensor A Out Of Range Low (Ratch too low) *
P1121 Throttle Position Sensor A Inconsistent With Mass Air Flow Sensor *
P1122 Pedal Position Sensor A Circuit Low Input
P1123 Pedal Position Sensor A Circuit High Input
P1124 Throttle Position Sensor A Out Of Self Test Range
P1125 Throttle Position Sensor A Intermittent
P1127 Exhaust Not Warm, Downstream O2 Sensor Not Tested
P1128 Upstream HO2S Sensors Swapped
P1129 Downstream HO2S Sensors Swapped
P1130 Lack Of HO2S11 Switches - Fuel Trim At Limit *
P1131 Lack Of HO2S11 Switches - Sensor Indicates Lean *
P1132 Lack Of HO2S11 Switches - Sensor Indicates Rich *
P1133 Bank 1 Fuel Control Shifted Lean (FAOSC) [ *]
P1134 Bank 1 Fuel Control Shifted Rich (FAOSC) [ *]
P1135 Pedal Position Sensor A Circuit Intermittent
P1137 Lack Of HO2S12 Switches - Sensor Indicates Lean
P1138 Lack Of HO2S12 Switches - Sensor Indicates Rich
P1150 Lack Of HO2S21 Switches - Fuel Trim At Limit *
P1151 Lack Of HO2S21 Switches - Sensor Indicates Lean *
P1152 Lack Of HO2S21 Switches - Sensor Indicates Rich *
P1153 Bank 2 Fuel Control Shifted Lean (FAOSC) [ *]
P1154 Bank 2 Fuel Control Shifted Rich (FAOSC) [ *]
P1155 Alternative Fuel Control Module Has Activated the MIL
P1157 Lack Of HO2S22 Switches - Sensor Indicates Lean
P1158 Lack Of HO2S22 Switches - Sensor Indicates Rich
P1168 Fuel Rail Pressure Sensor In Range But Low
P1169 Fuel Rail Pressure Sensor In Range But High
P1180 Fuel Delivery System - Low
P1181 Fuel Delivery System - High
P1183 Engine Oil Temperature Sensor Circuit *
P1184 Engine Oil Temperature Sensor Out Of Self Test Range *
P1214 Pedal Position Sensor B Circuit Intermittent
P1215 Pedal Position Sensor C Circuit Low Input
P1216 Pedal Position Sensor C Circuit High Input
P1217 Pedal Position Sensor C Circuit Intermittent
P1220 Series Throttle Control System
P1221 Traction Control System [ ] [ ] [ ]
P1222 Pedal Position Sensor B Circuit Low Input
P1222 Traction Control Output Circuit [ ]
P1223 Pedal Position Sensor B Circuit High Input
P1224 Throttle Position Sensor B Out Of Self Test Range
P1227 Wastegate Failed Closed (Over pressure) *
P1228 Wastegate Failed Open (Under pressure) *
P1229 Charge Air Cooler Pump Driver *
P1230 Fuel Pump Low Speed Malfunction (VLCM)
P1231 Fuel Pump Secondary Circuit Low, High Speed (VLCM)
P1232 Fuel Pump Speed Primary Circuit (Two speed fuel pump)
P1233 Fuel Pump Driver Module Disabled or Off Line (Fuel Pump Driver Module) *
P1234 Fuel Pump Driver Module Disabled or Off Line (Fuel Pump Driver Module)
P1235 Fuel Pump Control out Of Range (Fuel Pump Driver Module/VLCM) *
P1236 Fuel Pump Control Out Of Range (Fuel Pump Driver Module)
P1237 Fuel Pump Secondary Circuit (Fuel Pump Driver Module) *
P1238 Fuel Pump Secondary Circuit (Fuel Pump Driver Module)
P1239 Speed Fuel Pump Positive Feed
P1243 Second Fuel Pump Fault or Ground Fault *
P1244 Alternator Load High Input
P1245 Alternator Load Low Input
P1246 Alternator Load Input
P1260 Theft Detected, Vehicle Immobilized
P1270 Engine RPM or Vehicle Speed Limiter Reached
P1285 Cylinder Head Overtemperature Condition
P1286 Fuel Pulsewidth In Range But Lower Than Expected
P1287 Fuel Pulsewidth In Range But Higher Than Expected
P1288 Cylinder Head Temperature Sensor Out Of Self Test Range
P1289 Cylinder Head Temperature Sensor Circuit High Input
P1290 Cylinder Head Temperature Sensor Circuit Low Input
P1299 Cylinder Head Overtemperature Protection Active *
P1309 Misfire Monitor AICE Chip Fault, Misfire Monitor Disabled *
P1310 Ionization Misfire Detection Module Fault *
P1311 Ionization Misfire Detection Module Communication Fault *
P1340 Camshaft Position Sensor B Circuit *
P1351 Ignition Diagnostic Monitor Input Circuit *
P1352 Ignition Coil A Primary Circuit *
P1353 Ignition Coil B Primary Circuit *
P1354 Ignition Coil C Primary Circuit *
P1355 Ignition Coil D Primary Circuit *
P1356 Ignition Diagnostic Monitor Indicates Engine Not Turning *
P1357 Ignition Diagnostic Monitor Pulsewidth Not Defined *
P1358 Ignition Diagnostic Monitor Signal Out Of Self Test Range (no CPU OK)
P1359 Spark Output Circuit *
P1360 Ignition Coil A Secondary Circuit [ ]
P1361 Ignition Coil B Secondary Circuit [ ]
P1362 Ignition Coil C Secondary Circuit [ ]
P1363 Ignition Coil D Secondary Circuit [ ]
P1364 Ignition Coil Primary Circuit *
P1365 Ignition Coil Secondary Circuit [ ]
P1366 Ignition Spare [ ]
P1367 Ignition Spare [ ]
P1368 Ignition Spare [ ]
P1369 Engine Temperature Light Circuit
P1380 Camshaft Position Actuator Circuit (Bank 1) *
P1381 Camshaft Position Timing Over Advanced (Bank 1) *
P1383 Camshaft Position Timing Over Retarded (Bank 1) *
P1385 Camshaft Position Actuator Circuit (Bank 2) *
P1386 Camshaft Position Timing Over Advanced (Bank 2) *
P1388 Camshaft Position Timing Over Retarded (Bank 2) *
P1390 Octane Adjust Service Pin In Use/Circuit Open
P1400 Differential Pressure Feedback EGR Circuit Low Input *
P1401 Differential Pressure Feedback EGR Circuit High Input *
P1402 Exhaust Gas Recirculation Metering Orifice Restricted [ *]
P1403 Differential Pressure Feedback Sensor Hoses Reversed *
P1404 EGR Temperature Sensor Circuit *
P1405 Differential Pressure Feedback Sensor Upstream Hose Off Or Plugged *
P1406 Differential Pressure Feedback Sensor Downstream Hose Off Or Plugged *
P1407 Exhaust Gas Recirculation No Flow Detected [ *]
P1408 Exhaust Gas Recirculation Flow Out Of Self Test Range
P1409 EGR Vacuum Regulator Solenoid Circuit *
P1410 Auxiliary Air Cleaner Inlet Control Circuit
P1411 Secondary Air Injection Incorrect Downstream Flow Detected *
P1413 Secondary Air Injection Monitor Circuit Low Input *
P1414 Secondary Air Injection Monitor Circuit High Input *
P1431 Misfire Monitor Disabled, unable to learn trigger wheel profile *
P1442 Evaporative Emission Control System Control Leak Detected
P1443 Evaporative Emission Control System Control Valve *
P1444 Purge Flow Sensor Circuit Low Input *
P1445 Purge Flow Sensor Circuit High Input *
P1450 Unable to Bleed Up Fuel Tank Vacuum *
P1451 Evaporative Emission Control System Vent Control Circuit *
P1452 Unable to Bleed Up Fuel Tank Vacuum
P1455 Evaporative Emission Control System Control Leak Detected (gross leak/no flow)
P1457 Unable To Pull Fuel Tank Vacuum
P1460 Wide Open Throttle A/C Cutout Circuit
P1461 A/C Pressure Sensor Circuit High Input
P1462 A/C Pressure Sensor Circuit Low Input
P1463 A/C Pressure Sensor Insufficient Pressure Change
P1464 A/C Demand Out Of Self Test Range
P1465 A/C Relay Circuit
P1466 A/C Refrigerant Temperature Sensor Circuit
P1469 Rapid A/C Cycling
P1473 Fan Circuit Open (VLCM)
P1474 Fan Control Primary Circuit
P1479 High Fan Control Primary Circuit
P1480 Fan Secondary Low With Low Fan On [ ] [ ]
P1481 Fan Secondary Low With High Fan On [ ] [ ]
P1482 SCP [ ]
P1483 Brake Pedal Input Short To Battery
P1483 Fan Circuit Shorted To Ground (VLCM)
P1484 Fan Driver Circuit Open To Power Ground (VLCM)
P1485 Brake Pedal Input Short To Battery
P1500 Vehicle Speed Sensor
P1501 Vehicle Speed Sensor Out Of Self Test Range
P1502 Vehicle Speed Sensor Intermittent ^
P1504 Idle Air Control Circuit *
P1505 Idle Air Control System At Adaptive Clip *
P1506 Idle Air Control Overspeed Error *
P1507 Idle Air Control Underspeed Error *
P1512 Intake Manifold Runner Control Stuck Closed (Bank 1)
P1513 Intake Manifold Runner Control Stuck Closed (Bank 2)
P1516 Intake Manifold Runner Control Input Error (Bank 1) *
P1517 Intake Manifold Runner Control Input Error (Bank 2) *
P1518 Intake Manifold Runner Control Stuck Open (Bank 1) *
P1519 Intake Manifold Runner Control Stuck Closed (Bank 2)
P1520 Intake Manifold Runner Control Control Circuit *
P1530 A/C Clutch Circuit Open (VLCM)
P1532 Intake Manifold Communication Control Control Circuit (Bank 2)
P1533 Air Assisted Injector Circuit *
P1534 Restraint Deployment Indicator Circuit
P1537 Intake Manifold Runner Control Stuck Open (Bank 1) *
P1538 Intake Manifold Runner Control Stuck Open (Bank 2) *
P1539 A/C Clutch Circuit Overcurrent/Short (VLCM)
P1549 Intake Manifold Communication Control Control Circuit (Bank 1)
P1550 Power Steering Pressure Sensor Out Of Self Test Range
P1565 Speed Control Command Switch Out Of Range High
P1566 Speed Control Command Switch Out Of Range Low
P1567 Speed Control Output Circuit
P1568 Speed Control Unable to Hold Speed
P1572 Brake Pedal Switch Circuit
P1573 Throttle Position Not Available *
P1574 Throttle Position Sensor Outputs Disagree
P1575 Pedal Position Out Of Self Test Range
P1576 Pedal Position Not Available *
P1577 Pedal Position Sensor Outputs Disagree
P1578 ETC Power Less Than Demand [ *]
P1579 ETC In Power Limiting Mode [ *]
P1580 Electronic Throttle Monitor PCM Override *
P1581 Electronic Throttle Monitor Malfunction
P1582 Electronic Throttle Monitor Data Available
P1583 Electronic Throttle Monitor Cruise Disablement
P1584 Throttle Control Detected ETB Malfunction
P1585 Throttle Control Malfunction *
P1586 Electronic Throttle to PCM Communication Error *
P1587 Throttle Control Modulated Command Malfunction *
P1588 Throttle Control Detected Loss Of Return Spring
P1589 Throttle Control Unable To Control To Desired Throttle Angle *
P1605 Keep Alive Memory Test Failure [ ]
P1610 SBDS Interactive
P1611 SBDS Interactive Codes
P1612 SBDS Interactive Codes
P1613 SBDS Interactive Codes
P1614 SBDS Interactive Codes
P1615 SBDS Interactive Codes
P1616 SBDS Interactive Codes
P1617 SBDS Interactive Codes
P1618 SBDS Interactive Codes
P1619 SBDS Interactive Codes
P1620 SBDS Interactive Codes
P1625 Fan Driver Circuit Open to Power B+ (VLCM)
P1626 A/C Circuit Open to Power B+ (VLCM)
P1633 Keep Alive Power Voltage Too Low *
P1635 Tire/Axle Out of Acceptable Range
P1636 Inductive Signature Chip Communication Error *
P1639 Vehicle ID Block Corrupted, Not Programmed
P1640 Powertrain DTCs Available In Another Control Module (Ref. PID 0946) *
P1641 Fuel Pump Primary Circuit [ ] [ ] [ ]
P1642 CAN Link Circuit *
P1642 Fuel Pump Monitor Circuit High Input [DTC will be deleted on next version] [ ] [ ]
P1643 CAN Link ECM/TCM Circuit/Network *
P1643 Fuel Pump Monitor Circuit Low Input [DTC will be deleted on next version] [ ] [ ] [ ]
P1644 Fuel Pump Speed Control Circuit [ ]
P1650 Power Steering Pressure Switch Out Of Self Test Range
P1651 Power Steering Pressure Switch Input
P1656 CAN Link PCM/PCM Circuit/Network *
P1657 CAN Link Chip Malfunction *
P1700 Transmission Indeterminate Failure (Failed to Neutral)
P1701 Reverse Engagement Error
P1702 Transmission Range Sensor Circuit Intermittent
P1703 Brake Switch Out Of Self Test Range
P1704 Transmission Range Circuit Not Indicating Park/Neutral During Self Test
P1705 Transmission Range Circuit Not Indicating Park/Neutral During Self Test
P1709 Park Neutral Position Switch Out Of Self Test Range
P1711 Transmission Fluid Temperature Sensor Out Of Self Test Range
P1712 Transmission Torque Reduction Request Signal
P1713 Transmission Fluid Temperature Sensor In Range Failure (< 50 deg F) ^
P1714 Shift Solenoid A Inductive Signature *
P1715 Shift Solenoid B Inductive Signature *
P1716 Shift Solenoid C Inductive Signature *
P1717 Shift Solenoid D Inductive Signature *
P1718 Transmission Fluid Temperature Sensor In Range Failure (> 250 deg F) ^
P1727 Coast Clutch Solenoid Inductive Signature ^
P1728 Transmission Slip
P1729 4x4L Switch
P1731 1-2 Shift Malfunction
P1732 2-3 Shift Malfunction
P1733 3-4 Shift Malfunction
P1740 Torque Converter Clutch Solenoid Inductive Signature *
P1741 Torque Converter Clutch Solenoid Control Error
P1742 Torque Converter Clutch Solenoid Circuit Failed On *
P1743 Torque Converter Clutch Solenoid Circuit Failed On ^
P1744 Torque Converter Clutch Solenoid Circuit Performance *
P1746 Pressure Control Solenoid A Open Circuit ^
P1747 Pressure Control Solenoid A Short Circuit *
P1749 Pressure Control Solenoid A Failed Low
P1751 Shift Solenoid A Performance ^
P1754 Coast Clutch Solenoid Circuit ^
P1756 Shift Solenoid B Performance ^
P1760 Pressure Control Solenoid A Short Circuit Intermittent ^
P1761 Shift Solenoid C Performance ^
P1762 Overdrive Band Failed Off *
P1766 Shift Solenoid D Performance ^
P1767 Torque Converter Clutch Circuit ^
P1768 Performance/Normal/Winter Mode Input
P1770 Clutch Solenoid Circuit
P1780 Transmission Control Switch (O/D Cancel) Circuit Out Of Self Test Range
P1781 4X4L Circuit Out Of Self Test Range
P1782 Performance/Economy Switch Circuit Out Of Self Test Range
P1783 Transmission Overtemperature Condition ^
P1784 Transmission Mechanical Failure - First And Reverse
P1785 Transmission Mechanical Failure - First And Second
P1786 3-2 Downshift Error
P1787 2-1 Downshift Error
P1788 Pressure Control Solenoid B Open Circuit *
P1789 Pressure Control Solenoid B Short Circuit *
P1795 Inconsistent CAN Level *
P1804 4-Wheel Drive High Indicator Circuit Open or Shorted To Ground
P1806 4-Wheel Drive High Indicator Short To Battery
P1808 4-Wheel Drive Low Indicator Circuit Open or Short To Ground
P1810 4-Wheel Drive Low Indicator Short To Battery
P1812 4-Wheel Drive Mode Select Switch Circuit Open
P1815 4-Wheel Drive Mode Select Switch Circuit Short To Ground
P1819 Neutral Safety Switch Input Short To Ground
P1820 Transfer Case LO To HI Shift Relay Circuit Open Or Short To Ground
P1822 Transfer Case LO To HI Shift Relay Coil Short To Battery
P1824 4-Wheel Drive Electric Clutch Relay Open Or Short To Ground
P1826 4-Wheel Drive Electric Clutch Relay Short To Battery
P1828 Transfer Case HI To LO Shift Relay Coil Circuit Open Or Short To Ground
P1830 Transfer Case HI To LO Shift Relay Coil Circuit Short To Battery
P1832 Transfer Case 4-Wheel Drive Solenoid Circuit Open or Short To Ground
P1834 Transfer Case 4-Wheel Drive Solenoid Circuit Short To Battery
P1838 No Shift Motor Movement Detected
P1846 Transfer Case Contact Plate 'A' Circuit Open
P1850 Transfer Case Contact Plate 'B' Circuit Open
P1854 Transfer Case Contact Plate 'C' Circuit Open
P1858 Transfer Case Contact Plate 'D' Circuit Open
P1866 Transfer Case Cannot Be Shifted
P1867 Transfer Case Contact Plate General Circuit Failure
P1876 Transfer Case 2-Wheel Drive Solenoid Circuit Open Or Short To Ground
P1877 Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery
P1881 Engine Coolant Level Switch Circuit
P1882 Engine Coolant Level Switch Circuit Short To Ground
P1883 Engine Coolant Level Switch Circuit
P1884 Engine Coolant Level Lamp Circuit Short To Ground
P1891 Transfer Case Contact Plate Ground Return Open Circuit
P1900 Output Shaft Speed Sensor Circuit Intermittent
P1901 Turbine Shaft Speed Sensor Circuit Intermittent
U1021 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch Sense Input
U1039 SCP (J1850) Invalid or Missing Data for Vehicle Speed *
U1051 SCP (J1850) Invalid or Missing Data for Brake Input
U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant Fan Status
U1075 SCP (J1850) Invalid or Missing Data for Engine Oil Temperature
U1131 SCP (J1850) Invalid or Missing Data for Fuel Pump Status
U1135 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
U1451 SCP (J1850) Invalid or Missing Data From Anti-Theft Module, Vehicle Immobilized
U2015 SCP (J1850) Invalid or Missing Data From NGV Module
Hope ya guys can use this info. to the very best of your abilities when working
Discussion Starter · #11 ·
Woah. Thats a lot of codes. Much thanks for posting them all.
Does anyone think that because I need to replace my muffler (its making a funky rattling noise...and the outside shell is rusted through) that could cause a problem with the cat? Im wondering if perhaps one of the internal baffles is rusted and causing a restriction or something like that.....
Thanks again everyone for all the help....
~Bug
Discussion Starter · #12 ·
Hey there everyone.
First off, its one heck of a thread revivial. Secondly, my CEL problem seems to have just gone away. I ended up driving my car about an hour home on the highway in fourth gear instead of fifth, and I guess it just burned whatever was in my catalytic converter out of there. No problems since.
Thanks for all of the help offered, its much appreciated.
~Bug
It all goes back to your misfiring cylinder. This allowed hydrocarbons to partially coat the catalyt bed, thus giving you the catalyst efficiency code. After you dealt with the misfire condition and ran it hot enough for long enough, you burned off the HCs in the cat and now your world is just a bowl of cherries.
Important Lesson: Fix Sh!t When It Breaks. One problem can cause others and soon you can't make any sense of it.
The corollary is equally important: If It Ain't Broke, Don't Fix It. You'll end up breaking other sh!t along the way.
1 - 13 of 13 Posts
