1 - 5 of 5 Posts
my 93 escort 1.9 with auto trans is having some problems on city driving the trans shift fine but when you get on it pedal to the floor feels sluggish like a clog converter. but on the highway after 55mph the car will start jerking and get real sluggish and the trans will not downshift and then after a couple of second the car will get power and downshift and run good. if it was a clog converter it wil do it all the time so am thinking is a trans
Dirty MAF. A good cleaning should have you running strong again.
MAF (mass air flow) sensor first and then check to see you aren't grounding out on some plugs. When was the last time you did a tune up? I have a 5 speed and had the same problem. Even got the CEL (check engine light). I replaced all the plugs and wires and it went away.
Good luck
i have clean the maf before. i will try that again to see what happens. i did put spark plugs but no wires . i will be putting the wires by the weekend. and i let you guys know what happen.
1 - 5 of 5 Posts
