1 - 5 of 5 Posts
Sprayed maf sensor with some mafs rated cleaner put back together switched around ground cable on my battery for better connection. Starts ups sounding really strong but won’t even idle just dies right away. Can give it throttle to keep it alive for just a little bit but can’t find a sweet spot to keep her running. Any thoughts
1997 escort lx 2.0spi 187,xxx miles
Also just did clutch but have drove it around the block and it did fine😾
If I had to guess it sounds like you left the intake piping loose or disconnected a vac line. Either that or you are out of gas lol
It is possible that you damaged the MAF sensor if you did not let it completely dry before starting it up again, though I have never personally seen this happen.
1 - 5 of 5 Posts
