its normal for the car to idle high when cold then fall to 1000 RPM when warm
but as for stalling when does it stall?
it cant rev to a 1000 if it has stalled already
unless you mean i idles so low that it sounds like it going to stall then revs up again
if so i would look for a vacume leak[/quote]
ok, it seems to be an itermitnet problem. some times it runs fine. mostly it seems to run fine if I just jump in and run it (cold) or after I let it sit and runn up to temp, like if I let it run for 30 min..
now if it is just kinda wasm (like running for 5 min..) I Go to put the clutch in (its a stick) and as soon as I hit the gas it eater stalls or the RPMs drop below normal, like it wants to stall.
It seems that, when the car is acting up, if I hit the gas lightly, like ease it down, it will stay runing. but if I try to aply "normle" presure it stalls. the big problem is this seem to be intermint. it seemed to go away this summer and now is back to doing it sometimes now that it is cold..
any ideas?
