I hope this is the right place to put this question. I've had some trouble since I got a used pair of tires put on the front end of my 98 LX. shortly after getting the tires on, she began to lightly swerve right and left, at random. (I'll explain the swerve in detail below.) I figured that the wheels looked a little off center, so I straightened them out with the tie-rods. after doing that she began to swerve more severely and more often. I replaced the ball joints (they needed it), and now I'm back to the original problem. The wheels look REALLY close on alignment, and the ball joints are new, the tie-rods are solid, and the rack doesn't seem loose(I pushed and pulled on both sides really hard, with no movement at all. No amount of pushing/pulling/shaking of the wheels/car, jacked-up/on the ground makes the wheels move at all.
The swerve I'm getting is : I'll be driving straight and she lurches left or right, forcing the steering wheel to move as well. think if there was a really strong gremlin sitting in your steering column, and he's twisting your steering column 10-15 degrees at random when you're going straight. At this point(after the ball joints) I'm just barely not able to over power the jerking when it happens.
Anyone have any Ideas what could be causing this?
(Side note: Don't know if this helps, but my break rotors are wearing quite unevenly. My passenger side rotor is worn a lot more than my driver, and the inside of the passenger side is worn way more than the outside of the passenger side.)
Thanks for any help!
