my bp only turns on when i open the vaf flap with my hand. Or else the car doesn't turn on. exhaust gas temperature is very hot because fireballs come out from the exhaust manifold, and other parts of the exhaust piping are getting very hot as i can tell because the inside of the car is burning hot because the heat is transferring from the piping to the chassis. I think plugs, wires are good because the car runs once u open the vaf. you can rev it and all. i tried to check for codes but it didnt flash anything.
idk how to tell if its running lean, i've switched between 2 u code vafs that i have and same problems on both
i have to keep holding the vaf or else if i let go the flap closes and it dies
