Hello everybody
I didn't post anything for a long time. Recently, after a period when my Escort run well, troubles started again.
It all started about 2 and a half months ago. I did my state inspection, and about a week after that escort was definitely not normal (it started before the inspection, except not on such scale). What happens, is that while driving, the car would jerk. Smooth acceleration is almost impossible, only with very gentle throttle. If gas pedal is pusched to the floor, the car jerks, hesitates, and sometimes makes a noise like a backfire/misfire/detonation/shooting_out_of_gun. It feels like the engine creates as much power as it can, but something is blocking the power from applying to the wheels.
After the state insp, when this problem was happening a lot, but not constantly, I changed oil (3000 miles). The problem completely went away. I went two days ago to Pennsylwania (from VA), which was about 1500 miles both ways, no problems on the way, and I got around 43-45 mpg @ 60-65 mph. After comeback, the car started jerking in next week after that. Now it jerks all the time for past two months. If anybody has ANY idea, suggestion, or hypothesis, please tell me so I can try it. Check engine light was on all the time, but looking for the jerking reason, I cleaned EGR pipe, and nice amount of carbon fall out. Now, check engine light comes from time to time. Codes pulled : 538 (KOER) and 542 (engine off). Neither one makes sense. Checked/replaced/100 % good and working: EGR valve, TPS, Fuel pressure regulator, Air filter, vacuum lines, sparkplugs, IAC valve, wires, coilpack, good quality fuel, fuel filter, MAF. Timing done about 30000 miles ago.
RPMs are about 1500 @ idle, drop to 1100, and then they usually stay at it. Sometimes they would drop to 650 with heavy engine vibrations only to go back up. The RPMs don't jump too much, but periodically it happens.
Exhaust from the engine to the end was replaced about a year ago, however there is a small crack in the noise absorber at the end.
Please, any idea appreciated.
Thanks
Oh, 1994 escort wagon, 180000 miles, manual
Thanks
