Ok, more info:
the harness with the 2 blue 2 green wires are connected to a little cylinder shaped black thing that is attached to the lower part of the engine/tranny. The other 4 wires go up toward the front of the car past the fan and in line with the radiator. I is hard to tell were it goes from there without removing the radiator. I am thinking this sensor unit with the blue and green wires has something to do with the fan operation, i think it might be a heat sensor or something. But anyway, all i need is for someone to open there hood and look down in that space between the fan and the intake. if you look hard in there you will see a black sensor with 2 green and 2 blue wires coming off of it. You can also look below the car as i did in the picture. The it will attach with a harness to the above mentioned wires. I just need to know which wires attach to which and my car will be saved. Please someone help me out with this.
