Can you swap a ztec head on this cars engine block | Ford Escort Owners Association (FEOA)
Discussion in 'Engine Tuning' started by Ranchgang, May 20, 2020 at 5:48 PM.
  1. Ranchgang
    Ranchgang FEOA Member
    9
  2. Swift
    Swift FEOA Donator
    496
    101
    293
    Nope, different block. I think it was only some of the dodge 4 cylinders where you could swap sohc head for dohc.
  3. pextor
    pextor Moderator Staff Member
    5,911
    778
    Lancaster, pa
    definitely not going to work.
  4. novanutcase
    novanutcase FEOA Member
    2,471
    586
    263
    It would probably be cheaper and faster to just swap in a Zetec.
    John
  5. 93scortluv
    93scortluv Administrator Staff Member
    3,960
    159
    315
    Rhode Island
    can do it with some Honda's too. frankensteining them.
  6. marclar
    8,881
    505
    seabeck WA
    the theory has been discussed before... the blocks them selfs are close to the same in many respects and i believe it will physically 'bolt on' but there are issues... besides oiling and oil drainback holes, the split port engine uses dome top pistons that would make the ztec valves smash into the piston heads... timing belt lengths and timing become an issue next. the voodoo in the pcm is programmed differently, and the engine would never run correctly without the ztec pcm....
    if anything, doing the whole ztec swap would be more cost effective.
