1 - 2 of 2 Posts
can anyone tell me what the stock specs are for the cams are. i wanna know if i should buy a aftermarket cam set with larger lobes or stick with the ExhIntake setup i have. cause i would assume the exhaust cam would be the same size as the aftermarket intake cam, right?
the cams i was looking at have 205 and 207 duration, im gonna get the adjustable cam gears to tune perfect but should i get those cams?
cams
I am pretty sure the cam profiles are different, if fact a cheap upgrade is to get an exhaust cam from the bone yard and cut the tabs off where the blender/dizzy (distributor) would mate with the cam and then install said cam on the intake side/obviouly after removing the intake cam.
There are a couple of tutorials on here with pictures included...This is the swap I am going to do until I can get the money to buy these
http://www.integralcams.com/
good luck and happy tuning
The BADMAN
1 - 2 of 2 Posts
