Old thread but damn was it helpfull, The drivers side was easy, but the passenger side was a bitch, I couldnt get the strut to go down low enough to turn the upper bracket, even when using a pry bar on the tire to push the tire down. So i tried unhooking the tie rod from the spindle and still couldnt get it down low enough. so I gave up, so the passenger is still pointing towards the engine and the drivers I have adjusted towards the windshield. the outside edge of the both front tires were showing wear bad.drommer said:1. Remove 4 upper mounting bracket, NOT top center nut.
2. Raise car body.
3. Push the mounting bracket downward and turn direction indicator to desired postion:
Towards Windshield = +14 Min Camber +14 Min Caster
Towards Fender = +29 Min Camber 0 Min Caster
Towards Front = +14 Min Camber -14 Min Caster
I had the same experience as Skeeter. The pass-side strut had way more force than I could overcome to turn the strut mount. Is there a trick on this??Skeeter said:Old thread but damn was it helpfull, The drivers side was easy, but the passenger side was a ****, I couldnt get the strut to go down low enough to turn the upper bracket, even when using a pry bar on the tire to push the tire down. So i tried unhooking the tie rod from the spindle and still couldnt get it down low enough. so I gave up, so the passenger is still pointing towards the engine and the drivers I have adjusted towards the windshield. the outside edge of the both front tires were showing wear bad.drommer said:1. Remove 4 upper mounting bracket, NOT top center nut.
2. Raise car body.
Duly noted.Intuit said:Those long rails underneath the body are a bad spot for supporting the car. They may distort and crush. Best spot is the control-arm rear mount. If those need to come apart then the hard body outside of them is next best; but will need to cushion the jack-stands with a few layers of old rag to avoid damaging the paint.
