1 - 11 of 11 Posts
· Premium Member
I finally got around to swapping these goodies into the blue car.
Valve Cover off:
Rockers and Lifters out:
Cam and Cam Gear out:
Stock VS. BAT H-280(stock bottom, BAT top, see something interesting here?):
Stock Roller Lifter VS. BAT Hydrolic Lifter:
Cam back in:
Lifters in:
Rockers In:
What did I need from the stock Cam?
Cam Gear installed:
All together:
50% UDP installed:
I put the motor mounts back on, as well as the battery and intake, and fired it up for a few runs. I had to clean my IAC, but it is running pretty good now, and sounds MEAN!!! I have a few videos, that I will post up later.
**and before anyone mentions it.... I have purchased a 3rd gen throttle cable, which will be going on the car in the near future. I have just been working on other things right now, and the stock 94 throttle cable works just fine how I have it modified.
· Premium Member
HAHA, I hope for nothing... and then act suprised if I get an increase. It at least sounds better than it did before. I have a few things to button up before I can take it out for a test run.
Freaking sweet!
Some day I'll do this stuff to mine. Some day WAY down the road.
Hopefully you can get the serpentine belt length figured out.
· Premium Member
Discussion Starter · #8 ·
I figured rather than copying the specs, I'd just snap a pic:
And Celery... I have Stainless lines, they just aren't on yet.
· Premium Member
Discussion Starter · #11 ·
the cam is a BAT-Inc cam. They haven't sold Escort parts in many years now. The Alternator pulley that is currently on the car is a ZXTuner ODP to help charge the battery with the 50% crank UDP.
4door... the site that I used to host my videos on went down, so now I have all my videos on Myspace.
1 - 11 of 11 Posts
