1 - 10 of 10 Posts
What exactly is the issue that you have? Door dropping? You may need new pins and bushings. And I think the hinges on my f-150 are a little bigger than any of the Escorts.
Are you sure it's the springs, and not the nylon tensioner rollers? They snap and fall off, then the door won't stay open.
That's funny, because my driver's side spring is broken, too. If you look in there, it looks like it just snapped right off. I haven't approached the issue yet because it looks like I'd have to remove the whole door to gain access to it.
Yeah, it's the metal tab thing pictured above. The passenger side is fine, the other is snapped clean in half.
1 - 10 of 10 Posts
