So, on my 97 Escort I replaced my radiator, flushed the cooling system, and while I was at it I decided to replace the thermostat since I had the system, drained. As I'm removing the last bolt on the thermostat housing, snap! Broken bolt on the first quarter turn.
Not sure what to do, so I reinstalled the other two bolts and coil pack, air filter and radiator hose, filled the cooling system and decided to see if it leaks or not. No leak, it's only been a day, but I should take care of the broken bolt before it becomes a problem.
Any advice? The bolt is broken just below the surface. It seems that using a left handed bit to drill a pilot hole for an EZY-Out would be tricky, but maybe my only option...advice?
