Brakes | Ford Escort Owners Association (FEOA)
Brakes
Discussion in 'Suspension' started by K9kamper, May 23, 2020 at 9:27 AM.
  1. K9kamper
    K9kamper New Member
    Im working on a 03 ford escort zx2 found a 94 escort gt with rear disc brakes i want to know if itll fit
  2. krux303
    krux303 FEOA Member
    46
    6
    8
    Yes they will fit. Not sure if a write up is here but there should be one over at evilzx2s.com
    Sent from my LG-H872 using Tapatalk
  3. Swift
    Swift FEOA Donator
    496
    101
    293
    Just drop crossmember and trailing arms from gt and bolt into car. Also grab the two metal proportion valves that come off the gt master cylinder.
  4. krux303
    krux303 FEOA Member
    46
    6
    8
    When I switch my rears from an sr I kept my drum master and didnt notice a difference? I have the sr Proporation valves but up to you to try it first.
  5. novanutcase
    novanutcase FEOA Member
    2,471
    586
    263
    Actually you don't even need the crossmember as the spindles will bolt directly to the crossmember, at least on the 3rd gen. The trailing arms also didn't need to be changed. Master I used was from a Tracer wagon with RDB's/
    John
