1 - 7 of 7 Posts
How big of a difference is there with the front brake assembly on my '95 lx as opposed to my little bro's 93 EGT? :construct:
Measure brake discs, if they are the same, your good. If the LX is running the smaller discs, you will need spindles from the larger disc setup. If the larger discs are put on the smaller setup, the calipers will not bolt up.(got wrong calipers before!)
cool tip, thanks. I would have measured them but the car is 2 counties away. I havent had time to drive that far.
There were 9" and 10" rotors. If your car has 13" wheels then you definitely has the smaller ones. I think after 93 they did away with the smaller ones.
The stock rims are 14" on it now.
Then you probably have the larger 10" rotors, same as the EGT.
1 - 7 of 7 Posts
