When I came home yesterday my 96 LX wagon that was sitting in the driveway had it's brake lights on. I last drove it the day before. Keys were out of the ignition. Pulled the fuses for stop and tail lights even disconnected pedal switch. Had to disconnect the battery.
Today played with pedal switch and wiring at rear right light. Noticed 12v on both wires of switch connector.
Now,connect battery and brake lights off until pedal pressed then they stay on until battery disconnect.
All other lights work as should. Drives normal
Is there a relay I should look for or stay looking at the hatch back?
