1 - 7 of 7 Posts
First of all i have a 94 escort gt.. i want to swap in a bpt.. seen all over the forum websites for these motors but if anyone can help and list some that are complete for a straight swap into the car i dont want to have to get a ecu or wiring harness from somewhere else .. if u can help id greatly appreciate it.. thank you. :D
i just helped out a freind with this last week , his is a 95 but im pretty sure its same , i know you have to pin in your tps sensor , and fab up a exhaust manifold . you should use your stock tranny . possibly adjust vaf , it was hunting until he did so . and use your old o2 sensor . i may be forgeting anything but ill tell him to do a post cause he took alot of pix . good luck
You can use your stock 3 wire tps. If you get an engine it'll come with the 4 wire on it. 4 wire is better but not necessary. You probably wont have to adjust the vam if its sealed.
1 - 7 of 7 Posts
