just got this car and it's not getting good fuel economy. figure it's due for a tune up so what do you guys suggest i change/check first
this one is at 145,000kilometres and has a service sticker expires in 148,000
i changed oil and checked the tranny for peace of mind. also went and put the new air filter
i'll change the fuel filter once it gets nice enough to work outside.
i want to pull some plugs just to have a look. what's a good replacement plug and wire for this engine? i'm gonna just test the wires before i spend money on new ones
canadian tire carries bosch wires and platinum plugss. what do you guys like to use and remember i live in canada.
another thing comes to mind is stiff steering. fluid checks out maybe this is normal? thinking maybe a bad tie rod might be causing all that racket too and dragging the car and the steering but then i hear noise is normal for these cars. anyway goes straight if you let go of the wheel. last owner also put two new mud+snow tires on the front not too long ago so i'm assuming it's balanced and the tie rods check out
bought the emissions valve too but can't find it
last but not least i've always had bad luck with ford ignition. looks to be an Ignition module passenger side/near firewall, right next to the washer fluid. it's all crappy looking covered in salt.
