I think you might be OK. My ´93 with 92 octane and a 55 shot of N2O doesn´t ping.. through 3rd anyway. Never squeezed in 4th or 5th, you might get some ping with 5psi there. Are you using a boost dependant FPR after the stock one? That will get you more fuel pressure, but not sure how much flow the stock fuel pump is good for, so it might be a mute point. What size turbo are you using? My MX-6 with the little RHB5 IHI could run 15psi, no ping, but with the .60 trim T3 it pings like crazy at 12. The turbo size will have a lot to do with it. Are you using an intercooler? Is there a link somewhere where I could read about your setup?
