1 - 2 of 2 Posts
I cant figure out which grit I should use on the sander. I started sanding it lastweek, and it kept eating the plastic instead of the bondo, should I go from 60 grit to something higher?
regardless of which grit you pick, the plastic is going to be softer than the bondo, so I don't think a lower grit will help. Are you using standard bondo or the flexible bumper filler? What are you using to sand w/? A block, your hands, a power sander?
1 - 2 of 2 Posts
