okay I´m fixing rust, and I just finished grinding down to bare metal and then putting on the "rust converter" stuff that I know wont work, but oh well.
Anyway, I bought some bondo spot putty and primer and base coat and I need to know the order that I need to do things in to make it work.
Is this right:
1.Grind to bare metal
2.Spray on rust converter stuff
3.Spot-putty and fill in any gaps
4.Sand spot-putty
5.Primer over spot putty
6.Wet-sand primer
7.Base coat
I also bought white primer and I have a black car. I was told that the light colored primer helps add "depth" to the black. Will this make the "fixed" area look different from the paint on the rest of the car (my GT is black)?
Is this right:
4.Sand spot-putty
6.Wet-sand primer
7.Base coat
