Boat anchor with no spark..... LOL | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by uglyducklingescort, Dec 17, 2008.
  1. uglyducklingescort
    uglyducklingescort New Member
    997
    Tulsa, OK
    OK OK OK, maybe I need my butt kicked for that one and Jeff will get his chance.
    1.9 no spark, for a friend and needing to travel just to look at it.
    Do the coil packs go out on these things quite often or where else should I look.
    -Steve
    PS be nice. LOL
  2. therieldeal
    therieldeal FEOA Member
    8,622
    19
    338
    Northeast CT
    no spark at ALL? did he check all four plugs?
    the coil pack tends to half fail... it contains two coils so you'll lose spark on 2 cylinders. For both coils to fail at the same time would be very odd, I'd look elsewhere.
    My friend drove her 01 until the serpentine belt was falling apart (brilliant). The shredded belt was hitting the crank position sensor, and wore through one of the wires. No signal from that... no spark, no run, no nothing. I pulled the harness out, cut and soldered the wires... runs great now.
  3. white-lightning
    white-lightning FEOA Member
    2,896
    186
    Salem, VA
    Check tha cam and crank sensors. I don't remember which one will cause the spark to stop.
  4. cklaubur
    cklaubur Former Escort Owner
    1,748
    41
    298
    Now in Mesa, AZ
    Like therieldeal said, the crank position sensor will cause the car to not run. The cam position sensor will just cause the engine to run the fuel injetors in batch fire mode, using more gas, but it would run.
    Casey
  5. uglyducklingescort
    997
    Tulsa, OK
    well now I am hearing the car tries to start. So hell I don't know. What all is involved on changing the crank sensor if need be? Everything else will be no problem.
    -Steve
  6. therieldeal
    8,622
    19
    338
    Northeast CT
    "tries to start" could just mean it turns over....
    the one i had to fix the crank sensor on was "trying to start" but had no spark or fuel at all. lol
  7. uglyducklingescort
    997
    Tulsa, OK
    Yeah I am going into this blind. just trying to do a favor for a friend.
  8. zzyzzx
    15,176
    1,222
    Nobody has mentioned timing belt yet? You people are slipping!
  9. FordMan59
    FordMan59 FEOA Member
    4,552
    442
    333
    Russellville, Kentucky
    Check the ignition module.
  10. Jeffescortlx
    Jeffescortlx FEOA Member
    8,421
    13
    338
    Minnesota
    Do you know for sure yet if there is no spark at any 4?
    Other wise I was gonna say what therieldeal allready covered, crank trigger sensor. (for being a bp guy he know's a little too much about the 1.9, closet SOHC lover eh?)
    Also it is possible for the crank pully to slip apart, there is a rubber ring between the hub and trigger ring.
    If there is spark, then check the timing belt. I'd check it out anyways.
  11. s0eebuch
    s0eebuch Guest
    259
    LOL, was this pun intended or not?
    x2 on the belt. And by 'trying to start' - does that mean it tries to fire but doesn't run or that the engine simply turns over?
    If you're helping a friend from afar, video with audio might help.
    Good luck!
  12. uglyducklingescort
    997
    Tulsa, OK
    LOL Poor Jon.
    Timing belt in good condition.
  13. zzyzzx
    15,176
    1,222
    How do you know that it hasn't slipped? The last time mine went, the belt was fine, but the belt tensioner went bad, allowing the belt to slip.
  14. sedanman
    sedanman New Member
    2,141
    Newport, IN
    The tensioner on mine JUST WENT OUT.But the belt is fine. But it's getting replaced while i'm at it. lol ugh. oh well.
    -Nick
