blower relay | Ford Escort Owners Association (FEOA)
blower relay
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by zx24u, Oct 6, 2008.
  1. zx24u
    zx24u Guest
    40
    i replaced the blower motor, resistor, checked all fuses and trust me i know where they are, all cluster switches (fan speed, climate control, etc.) and my fan still wont kick on....so i ordered a blower motor relay and i cant find where it goes...and no the relay is not right next to the motor, thats called a resistor...thanks guys
  2. homestead367
    homestead367 New Member
    516
    Indianapolis
    Make sure all the connections are plugged in. If they are not they wont work correctly. The connector on the bottom of the blower if it comes unconnected the blower motor will not work.
  3. ZX2Fast
    ZX2Fast New Member
    492
    7
    Indiana
    There is a cluster of relays under the dash. I think this is the location of the blower relay. It has these wire colors going to it:
    Blue: Relay power supplied from the wiper (20A) fuse
    Blue/Orange: Power for the motor supplied from the blower (30A) fuse
    Black: Ground
    Blue/White: Output to the blower motor
    You should check that wiper fuse.
  4. homestead367
    516
    Indianapolis
    If its not under there is very well could be in the engine bay relay box. I am guessing that the blower uses a bunch of power so its got have a decent sized relay.
  5. 98escort
    98escort Guest
    1,112
    Mine had a bad resistor under the left side by the fuses. It was actually cracked inhibiting it's functionality.
  6. zx24u
    zx24u Guest
    40
    under the dash is in take the dash out?
  7. zx24u
    zx24u Guest
    40
    ok...im really f'n pissed now...i replace the relay, resistor, blower motor, all three switches and traced the wires and i still cant figure the crap out...
  8. ZX2Fast
    ZX2Fast New Member
    492
    7
    Indiana
    PM me your email and I'll email you the wire diagrams from the Ford book.
