Big Brakes for a 2nd gen | Ford Escort Owners Association (FEOA)
Discussion in 'Wheels/Tires/Brakes' started by racetracer, Feb 14, 2007.
  1. racetracer
    racetracer New Member
    898
    Easten Shore of Maryland
    I bought a 11 inch wilwood four pot set-up for a honda civic, I'm in the procces of fabricating the needed caliper brackets
    once they are complete I will be able to make them for others
    fully cnc machined from 7075 grade stock
    cost should be about 110$ for the front pair (brackets)
    phase two will be a complete rear conversion kit for drum rear escorts
    including ss lines and 9 inch rotors.
    post or PM if your interested
    warning : this will not be a cheap modification, the wilwood kit alone costs 630$ for the front only
  2. therieldeal
    therieldeal FEOA Member
    8,622
    19
    338
    Northeast CT
    which wilwood calipers is this designed to use? if i may make a suggestion... the mazdaspeed miata had 11" front rotors... ;). and you can get used wilwoods pretty cheap...
    -jon
  3. racetracer
    898
    kit # 140-8695 is what I bought
    and it comes with
    # Forged Billet Dynalite FDL 4 Piston Caliper
    # 11.00” or 12.19” HP or SRP Performance Rotors
    # GT Series Aluminum Hats
    I priced used calipers , but after you buy a rebuild kit, and rotors your still looking at $450 ,so best to just buy new on this one
    also the miata is five lug rotors, I'd have to use civic rotors with this kit
    and I don't think sourcing the madzaspeed parts would be any cheaper
  4. therieldeal
    8,622
    19
    338
    Northeast CT
    the mazdaspeed miata had 4 lug rotors ;).
    [​IMG]
    -jon
  5. MATT91GT
    MATT91GT FEOA Member
    1,151
    6
    288
    Fullerton, CA
    yea you can already buy big brake upgrade kits for the miata that will partially fit our cars. i remember thinking about something like this back in november
  6. wasthatawagon
    wasthatawagon FEOA Member
    705
    37
    278
    Atlanta GA
  7. therieldeal
    8,622
    19
    338
    Northeast CT
  8. therieldeal
    8,622
    19
    338
    Northeast CT
    wait a second, thats friggin ghey... the rear kit uses the stock calipers! :(
    -jon
  9. wasthatawagon
    705
    37
    278
    Atlanta GA
    The brakes would be worth more than the escort.
  10. therieldeal
    8,622
    19
    338
    Northeast CT
    so, my (used) motor alone cost more than 5x what i paid for the car... haha this is what happens when you build these economy cars into performance monsters :D
    -jon
  11. TX907
    TX907 Guest
    114
    So did Precision Brakes change their name to Revolution Brakes? Prices went up significantly as well.
  12. TexasTracer
    TexasTracer FEOA Member
    4,694
    16
    188
    Sunnyvale, Texas
    That's why I'm surprised there's a big brake kit for our cars out there.
