Big 3 help | Ford Escort Owners Association (FEOA)
Big 3 help
Discussion in 'ICE (In Car Entertainment)' started by 99sportscort, Nov 1, 2010.
  1. 99sportscort
    99sportscort New Member
    59
    I plan on doing the big 3 wiring on my 99 spi. I've read i can replace the wiring or just add larger wiring to the factory, what do you guys suggest? Also how would i go about upgrading my ground? i'd swear i read on here some where that one of the grounds cant be upgraded, true? any other help/suggestions is appreciated! thanks
  2. neuspeedescort
    8,138
    101
    363
    wenatchee, wa
    everything can be upgraded. just remember to fuse between the alternator and the battery.
    NEUMAN
  3. racethisescort89
    racethisescort89 New Member
    2,391
    In your closet watching you secks!
    if i may ask the noob question..whats the big 3?
  4. 99sportscort
    59
    so is it ok to just add to my wiring instead of tearing it all out? and yes i have a 200 amp fuse. The big 3 to me (may be using the term incorrectly) is upgrading your alternator to battery +, battery to chassis-, and engine to chassis- to larger wire to allow more current flow.
  5. neuspeedescort
    8,138
    101
    363
    wenatchee, wa
    a-hole response: you know who i want you to ask this of don't you?
    friendly response: it is the upgrading of the power and ground lines to (most commonly) 0ga wire.
    1. alternator to battery
    2. battery ground
    3. engien/alt ground
    NEUMAN
  6. racethisescort89
    2,391
    Well thank you for your kinda words and generosity Neuman I just had never heard of it phrased that way before
  7. neuspeedescort
    8,138
    101
    363
    wenatchee, wa
    im just getting at you. when i heard the term for the first time i was like the wha? but anywyas. where has 4door been?
    NEUMAN
  8. 99sportscort
    59
    Alternator to battery i understand, little help with the grounds? One wire leaving my negative battery post instantly goes into a black plastic thing and splits into 2 wires then goes off into a big main loom. The other wire from my negative terminal has a yellow strip on it. it goes for 5 inches is grounded to the body and then continues down under my battery and into a large loom also.
    So how do i upgrade these? sorry to be such a noob.. all the pictures i look at people just have 2 big 0/1guage wiring running from their battery ground to the chassis and one to the engine(and the postitve to alternator). so what do i do with the wire that splits right away? and can i just swap out that 5 inches to the chassis and leave and rest that goes on into the loom alone? Thanks for the helps guys!
    Also i just recieved my h/o alternator (thats why im doing the big 3) and it has a smaller pulley by half an inch, will i require a smaller belt?
  9. neuspeedescort
    8,138
    101
    363
    wenatchee, wa
    the negative of the battery should only have one wire. the power is the side that has multiple.
    you need to ground your engine to the chassis also. that is 3
    NEUMAN
  10. 4doorscort
    4doorscort New Member
    8,129
    5
    Brampton ON
    deffintly go with 0 gauge, nothing smaller then 4 gauge otherwise your wasting your time imo.
    And I'm around Neuman ;)
  11. racethisescort89
    2,391
    lmfao why did you ask for 4door Neuman? miss him?
  12. neuspeedescort
    8,138
    101
    363
    wenatchee, wa
    part of my likes him. LOL
    he is dead on tho. i built a harness upgrade back a few years ago for my copper car that is high count 100% ofc 8ga to replace all the stock power and ground. that was before i decided to put a larger stereo in. now i have a harness that is really nice but a waste. i may redo it or sell it to a race car person.
    NEUMAN
  13. ESCORT_me
    ESCORT_me New Member
    44
    san lorenzo, CA
    if you google "big three" you will get a better idea than other peoples opinions here...and dont use "gauge" use "awg" american wire gauge its bigger and better quality then "guage" wire and if you got the few extra bux get marine awg(ebay gots it hella cheap 1+ by the foot)...all the cheap wire boast "gauge" when infact you find "awg" on real power wire(im using american made 2 "awg" monster COMP. wire through out my 99 se i also done the "big three" but used 0 marine awg for big 3 under my hood)...DONT BUY "GAUGE" BUY "AWG" WIRE!!!! way better current draw and safer for your CAR electronix!...
  14. pnmred
    pnmred FEOA Member
    306
    27
    178
    MIDWEST
    he's right AWG is standardized
  15. racethisescort89
    2,391
    im actually thinking of upgrading to 4GA now i say at my local parts store battery terminals with wire 4GA for 12$ would JUST battery wiring being larger have an effect?
  16. ESCORT_me
    44
    san lorenzo, CA
    get a deep cycle battery if you want more "effect" :)
  17. neuspeedescort
    8,138
    101
    363
    wenatchee, wa
    i don't know of a lot of automotive style power wire that is marked AWG.
    now marine wire may be the same but if you want the good stuff get welding cable. very high strand count OFC large diameter and fine strands also. top shelf in my book. but not many people around here (including myself) really need it. however if your going huge its a must. that or some double-0.
    so the marine wire your rocking is it the tinned stuff?
    NEUMAN
  18. racethisescort89
    2,391
    see i say AWG cuz thats the only wire guide im aware of lol
  19. pnmred
    pnmred FEOA Member
    306
    27
    178
    MIDWEST
    A standard battery would have more total surface area on its plates when compared to a deep cycle battery of equal size. This extra surface area provides more area for the chemical reaction to take place and therefore produce a higher output current
  20. neuspeedescort
    8,138
    101
    363
    wenatchee, wa
    oh really? look into a stock battery for an escort. its going to be 450-600 cca. a deep cycle is 800-1000 cca.
    NEUMAN
