Best way to prevent dropped valve seats ? | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by ncscort, Mar 1, 2008.
  1. ncscort
    ncscort Guest
    42
    As a measure of preventive medicine - what would you recommend to prevent a dropped valve seat before it happens ?
    It's a 94 lx 1.9....
    Can the existing head be removed and fitted with better valve seats ?
    Should a later model head be used and if so which year ?
    Engine is running perfectly, just want to make sure it continues that way !
    Thanks
  2. madmatt2024
    madmatt2024 FEOA Member
    9,925
    438
    383
    Upstate N.Y.
    Yes, the seats can be replaced.
    Best thing you can do is not to let the engine overheat. Make sure your rad fan operates the way is should, if the engine starts getting hot don't continue driving it, find the problem and fix it.
  3. Jeffescortlx
    Jeffescortlx FEOA Member
    8,421
    14
    338
    Minnesota
    Yep, dont let it over heat. That will help. I guess, I dunno. I've been driving Escorts now for 6-7 years and never dropped one.
  4. escortrio
    escortrio FEOA Donator
    890
    7
    268
    st. louis, mo
    the one mine did drop in my temperature guage didnt work and i reved the crap out of it in snow one day so ya keep that cooling system in good shape and you'll probably be alright.
    i know that car was treated like crap from the day i bought it, rust in the anitfreeze, clogged heatercore, idle/vaccum leak and it sounded like crap especially nears its death sounded like a valve sapping noise or something but it was a pony so i couldnt resist
  5. zzyzzx
    15,278
    1,247
    Don't drive the car. Mine never overheated, but dropped a valve seat at 72,000 miles anyway.
  6. TexasTracer
    TexasTracer FEOA Member
    4,694
    17
    188
    Sunnyvale, Texas
    Really it's a good luck bad luck thing.
  7. zzyzzx
    15,278
    1,247
    I agree (I was just kidding about not driving the car above, even though that will prevent the valve seat from dropping). About the only thing you could do is get a valve job once you get a lot of miles on the car and could use one anyway due to wear. Or just keep enough money handy in case you need to fix it after it drops. 8O
    Yeah, and I did bitch to Ford and they didn't care (sent me back a letter that was laughable).
  8. TexasTracer
    4,694
    17
    188
    Sunnyvale, Texas
    That's what I'm going do while keeping my fingers crossed daily. :?
  9. celery952
    celery952 FEOA Member
    1,985
    286
    Villa Ridge, MO
    my 1.9 did at like 90k I picked up my spi for 200 bucks with 175k on it which had dropped one
    I saved a piece out of the 1.9 seat I found in the intake :)
  10. EscorGo
    EscorGo FEOA Donator
    3,006
    139
    213
    Wichita, KS
    Is it just the intake valves that let go? Do the exhaust valves need to be replaced too?
  11. escortrio
    890
    7
    268
    st. louis, mo
    i know its usualy one or the other always starting at the 4th cylinder but i would buy a head from ebay since they have everything done and come with a 1 yr warranty and thats probably about the price it would cost to have it done.
  12. celery952
    1,985
    286
    Villa Ridge, MO
    the head I bought off ebay said it had the upgraded seats so the problem wouldnt happen again.... but who knows I doubt I will ever put another 200k on the car to find out
  13. zzyzzx
    15,278
    1,247
    So if I understand you correctly, you have had it happen twice?
    :eek:
  14. celery952
    1,985
    286
    Villa Ridge, MO
    yes once on my 2nd gen, and I bought my 3rd gen with a dropped seat
  15. zzyzzx
    15,278
    1,247
    Which is why I don't use JY engines!
  16. celery952
    1,985
    286
    Villa Ridge, MO
    ? jy engines? the jy engine that I put in the 2nd gen, is in cklauber's car still running great, and my 3rd gen I bought a new head for.......
  17. EscorGo
    3,006
    139
    213
    Wichita, KS
    Crap. You guys have me convinced on getting my valve seats replaced on a fine running JY engine before I drop it in my wagon. I'm already replacing front and rear seals, pan gasket, the oil pump, the water pump, timing belt and tensioner. I'm the poster child for Murphy's law.
    http://www.murphys-laws.com/murphy/murphy-laws.html
  18. Silex
    Silex New Member
    863
    Brampton , ON
    dont over heat? why not jeff , ive over heated my ministock MANY times ( Highest record temp for me was 265*F !!) 310k kms/193k miles 180psi accross the board :p I've had NO issues as of yet and im TRYING to kill it LOL , she just wont die , idles SOLID not even a sputter anywhere.
    and you call that luck ? I'm WELL known for cracking engines
    This one just has a soul ;)
  19. TexasTracer
    4,694
    17
    188
    Sunnyvale, Texas
    Might as well if your replacing all the seals and gaskets.
  20. escortrio
    890
    7
    268
    st. louis, mo
    it'd be alot nicer if it dropped and at least kept the top of the pistons in good shape, two of mine were all chipped but maybe that was from repeatedly trying to start it when i knew it wouldnt.
    i had a good head too, il know better if that happens again
