Best tool for holding crank still whilst tightening/ removing crank bolt? | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by 95GTOwner, Aug 29, 2015.
  1. BOSS302man
    BOSS302man FEOA Donator
    2,665
    44
    198
    Lebanon, PA
    Can't 'beet' that idea!
    Maxwelhse likes this.
  2. Intuit
    Intuit FEOA Member
    7,552
    926
    Southwest Ohio
  3. Maxwelhse
    Maxwelhse FEOA Member
    783
    181
    103
  4. farva
    farva FEOA Member
    26
    103
    if the trans is off, many auto parts stores carry (on the shelf) a flywheel holder. you just bolt it up in one of the holes for the trans and it has 2 teeth that hold the flywheel in place.
  5. dchawk81
    dchawk81 FEOA Member
    3,450
    940
    173
    Confirmed on the corded electric impacts. They'll take off what you can remove with a regular ratchet but not much more.
    My cordless, however...that's 780lbs working and 1100 "nut busting" so it'll do some work. Cost $460 though but it's cheaper now...a tick under $400.
  6. dchawk81
    3,450
    940
    173
    The upside to those corded and cheaper cordless impacts is they'll zing many fasteners off a lot quicker than you can do it by hand, saving a boat load of time.
    Most aren't that tight in the first place. It's rare to need crazy power. When I stripped my other Escort down to scrap it, I used Harbor Freight's battery impact almost exclusively. I don't find the IR W7150 electric and Nitrocat 1250K air necessary MOST of the time from a brute force standpoint but they're just a helluva lot faster on what the old one could also remove.
    So yeah in short, even the "weak" ones have their place...if for no other reason than to save your back or time.
  7. Intuit
    Intuit FEOA Member
    7,552
    926
    Southwest Ohio
    A cordless drill can be better than a wannabee impact.
  8. dchawk81
    3,450
    940
    173
    A cordless drill doesn't function the same way an impact does.
  9. Intuit
    Intuit FEOA Member
    7,552
    926
    Southwest Ohio
    ...yes, I know.
  10. dchawk81
    3,450
    940
    173
    So it can't be better. Only different.
  11. Intuit
    Intuit FEOA Member
    7,552
    926
    Southwest Ohio
    You're thinking in absolutes. "Can" doesn't translate to "always." Instead of buying a "weak/cheap" impact, consider the good cordless drill that many of us already have.
  12. dchawk81
    3,450
    940
    173
    Except it can't. Because it's not the same thing. At all. Not even in some ways. It doesn't do the same thing.
    If you want to spin something, get a drill. If you want to beat it off, get an impact.
  13. Intuit
    Intuit FEOA Member
    7,552
    926
    Southwest Ohio
    Correction: Get a *REAL* impact.
  14. dchawk81
    3,450
    940
    173
    Well a real drill isn't going to do you any favors over a wimpy impact if you need to beat off a fastener, since a drill will just stop.
    My HF impact was what you might call wimpy but it did its job.
  15. Intuit
    Intuit FEOA Member
    7,552
    926
    Southwest Ohio
    Experiences differ. My drill does better than another Harbor Freight "impact" purchased several years ago.
  16. dchawk81
    3,450
    940
    173
    My drill is a Porter Cable with good power and speed but it still doesn't do what even HF's cheap battery impact will do.
    Having said that, I got rid of it because of how fast the batteries ran down. It was really useful otherwise. Tore down the first Escort with it, just had to keep batteries on the charger. It failed on some crossmember bolts and axle nuts but that's about it.
    I replaced it with the biggest step up I could find though so there's no doubt about capability now. Axle nut? What axle nut? Oh you mean the one on the floor already.
  17. BOSS302man
    2,665
    44
    198
    Lebanon, PA
    Mines bigger than yours!
    You guys done?
  18. dchawk81
    3,450
    940
    173
    Nevaaaaaa!
  19. Intuit
    Intuit FEOA Member
    7,552
    926
    Southwest Ohio
  20. dchawk81
    3,450
    940
    173
