Bench testing a starter | Ford Escort Owners Association (FEOA)
Discussion in '1st Gen 1981-1990 CVH' started by NeckDelight, Jan 4, 2020.
  1. NeckDelight
    NeckDelight FEOA Member
    122
    38
    278
    So I have a engine I got to put in one of my escorts. The guy I got the engine from is a credible seller. I bought a good running Scort off him. I would like to give this said engine a compression test. The transmission is not on it I have a bracket made so the start will mount to the engine. I am wondering can I just take a spare battery take jumper cables take my ground lead to the casing or anywhere on the engine and positive jumper to the hot battery portion of the starter to get this thing to crank. Again I just want to give it. Compression test before I go through and replace all the seals in this engine. Kinda like a piece of mind. Am I wayyy of in thinking I can do this
  2. zzyzzx
    15,187
    1,225
    Sure you can. I would be sure to have the starter secured.
  3. NeckDelight
    122
    38
    278
    Yeah it will be mounted to the block. I was just making sure there wasn't anything I was missing I think the two starters I have in my parts supply don't work ha.
  4. denisond3
    10,130
    2,833
    The normal way is to hook the +12 volts to the large terminal on the top of the solenoid, and use a smaller +12volt wire connected to the small terminal on the solenoid. This way the solenoid will pull the 'bendix' mechanism into contact with the teeth on the starter ring, before the starter starts spinning the engine.
    I do my compression tests by leaving the throttle shut. It doesnt give as high a reading as doing it with the throttle open; but its just as good a relative measure of compression. I let the engine turn about 6 or 7 times per cylinder, and I do that the same for each of the four cylinders.
    Replacing the main seals is a good idea, while the engine is out of the car. I would also recommend replacing the five core plugs on the block. Four of them are the same size; two on the front of the block and two on the backside. The one on the end of the block is larger, (3-1/16" I think); since that one can only be reached when the flywheel or flexplate is removed from the crankshaft.
  5. zzyzzx
    15,187
    1,225
    Starters are often easily repaired.
  6. NeckDelight
    122
    38
    278
    I was planning on taking them apart and see what's going on inside
  7. zzyzzx
    15,187
    1,225
    Good. Should be simpler than an alternator, since no diodes or regulator. Might just need brushes.
  8. denisond3
    10,130
    2,833
    I have found it necessary to clean the muck off the commutator on starters. And you have to ensure the gaps between commutator segments are cleaned out too.
  9. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,508
    1,170
    Vancouver Island, Canada
    I remove the spark plugs from all the cylinders and do the compression test at WOT.
    However you do it, the relative difference is the more important value. I often find that the starter is slowing down by the last cylinder due to the battery losing strength.
    denisond3 likes this.
  10. NeckDelight
    122
    38
    278
    That's exactly how I give a compression test. I have the engine sitting in the garage just sitting in a engine stand. I have the starter bolted to the engine now I want to do a compression test. Checking the engine before I put it in the car
  11. Krankie
    Krankie FEOA Member
    39
    38
    18
    Syracuse NY
    This is a gen 1 no? first gen Escorts don't have a stareter-mounted solenoid. The solenoid is on the fender well next to the battery. Grounding the case and putting positive cable to the cable lug on the starter should light it right up. The bendix is mechanically engaged by rotational forces.
    This is got to be the same guy I responded to on Facebook the other day.
  12. denisond3
    10,130
    2,833
    My mistake, sorry.
  13. NeckDelight
    122
    38
    278
    Yeah I have two junk starters sitting on my shelf ha. Imagine that
  14. Joey_Twowagons
    2,508
    1,170
    When the solenoid on my starter quit, I bought a core starter at a the local junkyard for $10 and took the solenoid from it.
    These 1990s PMGR Ford starters seem to all be the same other than the snout. The starter on a late 351W engine I have is the same basic unit as the Escort 1.9 (!)
