is there a way out there to be able to change the rubber timing belt to a chain belt so that you don´t have to worry about it breaking at all? the new Nissan Sentra SE-Rs have "no maintenance" chains on them.
[/TD][/TR][TR][TD]10-02-2003 at 17:11, Beaverboy wrote:
You guys are scaring me! Why on earth would it take you a week to replace the belt? You cut your thumb off, got it surgically replaced and then let it heal before finishing right?
[/TD][/TR][TR][TD]It took me a week because I did it in little bits after work in my driveway with little in the way of proper mechanic´s tools, and it was my first and only timing belt job. There´s barely enough room for your hand between the end of the motor and the sheetmetal. The wheel has to come off. I could go on...
