Bell-housing to Engine Block Spacer Plates | Ford Escort Owners Association (FEOA)
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by JRTobbe, Mar 3, 2020.
  1. JRTobbe
    JRTobbe New Member
    Hi,
    I pulled the motor from my 2000 Escort ZX2 S/R last weekend.
    2.0 DOHC, Manual Trans
    In the process, we bent up 2 spacer plates between the bell-housing and motor when we pried them apart.
    These were sheetmetal plates with holes for the main bell- housing mounting bolts.
    I can't find any information on these plates/ gaskets for ordering.
    Are these OEM parts or did someone custom make these to band-aid a crank-walk problem?
    Any leads on where to purchase, or are they not needed?
  2. JRTobbe
    JRTobbe New Member
    Found an older thread mentioning that the Manual Trans does have 2 spacer plates.
    I still can't find any mention of them across the internet.
    Hopefully, the used motor I buy has a set in good condition.
  3. marclar
    8,883
    505
    seabeck WA
    your talking about the stamped sheet metal spacer sandwiched between the engine and trans, just to clarify? the plate has nothing to do with crank-walk, mostly it is for keeping dirt out of the bell housing. you can lay it down on a hard surface and beat it back into shape with a hammer if you need to.
    Racecar likes this.
  4. JRTobbe
    JRTobbe New Member
    Gotcha. Those are the ones.
    I had to pull my engine for a bad crank.
    I had never seen those plates before, so I was confused as to the purpose.
    Still surprised I can't find one for sale.
  5. Racecar
    Racecar FEOA Member
    21
    9
    63
    Iron ridge Wisconsin
    Usually don’t sell many if any of those. Just make some out of 1/8” plates if you want new ones.
  6. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,343
    1,068
    Vancouver Island, Canada
    Check the dealer for those plates.
    If you do straighten them, don't put in sharp kinks. I have had good luck just using my foot with the plate on the ground. But that was the V8 ones, which are only about 1/16" thick.
  7. marclar
    8,883
    505
    seabeck WA
    whats the story with the bad crank? r u pulling another doner engine? if so take that ones plate
  8. 4cylinder
    4cylinder FEOA Member
    693
    126
    193
    san diego, ca
    the 5speed uses two pieces. The automatic only uses one. If you get a donor from an automatic car then you will need to reuse the one closer to the trans as that is the one specific for the 5speed
