Ya'll mighta seen my post in general discussion (94egt goes down again) and I wanted to post an update here to see if it helps narrow down what happened since I've been too lazy to do much other than be glad it's starting with a quickness and running good. This past Sunday it didn't start and then after a jump was starting only after holding the key down awhile.
The day before this happened it was starting completely fine. We thought it could be the alternator that had been recently replaced or the refurbished battery I had in there. We put the Die Hard battery I used to have back in the car and now it's starting perfect. It's been four days since we put it in there...would I have an indication by now that the alternator was bad? When my first alternator went bad it started to take a longer and longer time for the car to turnover, but that's not happening this time.
How long would it take for the battery to loose it's charge without the alternator? It seems it took a long time last time cuz the long turnover period was on and off for about three months before it became consistant and finally didn't start at all. So I guess the alternator was probably really weak for awhile, but that Die Hard seems to be very strong. I just wonder when I can reliably say it was probably the bad battery.
