I replaced both front ball joints and tie rod ends on my 99 3rd gen 7500 miles ago. When I first drove it, it made a crunching/clunking noise. It didn't seem like I had tightened the ball joint bolts up enough by hand, so I took an air impact wrench to it. This snugged things up nicely and no more clunking/noise, until just a few days ago. It seems like the drivers side started making the same clunking noise it made when the bolts were loose. I pulled the wheel off and checked it out, and the pinch bolt and outer ball joint to control arm bolt (outer meaning closer to the wheel) seemed a little loose. I took the air impact wrench to the pinch bolt and it immediately stripped and started spinning. Next, I tried to tighten the ball joint bolt by hand, but after a little resistance, that one started spinning. It is definitely stripped, as I was holding the opposite end of the bolt with a wrench while I tried tightening it.
Why are these bolts stripping out? Is the bolt stripping, or the nut (I would assume the nut would be weaker?) Did I do something wrong, or did I just get cheap/crap hardware with the replacement ball joints? Lastly, does the pinch bolt need to just stay in its groove, or actually be tight? I need to drive this as-is for the next week before I have time to work on it..
