1 - 3 of 3 Posts
I had a wreck with a curb, so I Rebuilt everyting, strut, balljoint, tie rod end boot, and a new control arm. I did this and the other side since I might as well do it you know. So I swapped the strut mounts sorta on accident, and now about 4 months later that side is making this funny sorta rattle almost like its 2 washers smaking each other. Well it makes this when u hit a bump, but if u lightly hold the brakes, no noise. So is it the strut mount or something else?
I realize I'm a little late to respond.... My best guess is that the strut isn't tight - try taking a torque wrench to the nuts and make sure everything is bolted up tight. Otherwise when the suspension moves, your strut will wiggle in the mount and could make that sound.
1 - 3 of 3 Posts
