This past month I have found that my A/C isn't getting as cold as it normally has been. Naturally, I thought that it just needed its freeon topped off but it's pressure is fine, and in fact the problem is that the radiator fan never turns on so the A/C condenser overheats and shuts down.
I did some more testing and I found that if I leave the A/C on and drive on the freeway for about 5 miles, the air moving through the radiator keeps the A/C running cool. When stopped at a light, the A/C stops cooling and the engine temp meter on the dash skyrockets into the red - which is remedied by turning the A/C off and turning the heater on full blast until the engine cools back down.
Through it all, the rad fan never turns on. There are three wires going into the fan's motor. My VOM shows two of the wires have 14V on them, while the last is neutral. This leads me to believe the fan motor itself is faulty, and the relay and temp sensor are working fine.
Does that sound about right?
The problem is - I don't know for sure what all three wires do. Obviously one is ground, but are the other two used for different coils in the motor or are they connected to a relay inside the motors housing?
