1 - 5 of 5 Posts
I have a 92 wagon with the automatic shoulder belt. I would like to permantly disable them in the back posistion so I can still use them. I just dont want something to crap out like the motor or track system. I cant find the wiring at all in my Haynes manual. Anyone know of a fuse, circuit breaker or motor wiring connection is at. Thanks
i have an idea is someone wants to try something new.
pull the upper b pillar trim back and see if you have a random tapped bolt hole that is about 1cm in diameter. The canadian proteges had the "normal' seatbelts. someone in canada or with a friend in canada could _see_ if they fit. i know of a few protege's being parted out.
1 - 5 of 5 Posts
