Auto transmission noise | Ford Escort Owners Association (FEOA)
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by steve60tuesday, Feb 27, 2020.
  1. steve60tuesday
    steve60tuesday FEOA Member
    50
    23
    18
    I've had this issue with my '01 auto transmission for a couple of years now, and am wondering if anybody else has had the same problem.
    Cruising at highway speeds, whenever the torque converter unlocks, I get a weird grinding noise for a few seconds. It sounds kind of like a two-stroke dirt bike, or like an exhaust heat shield rattle. But it is not a rattling heat shield, and this isn't a dirt bike. It is very loud and somewhat alarming, but it goes away gradually over 2-3 seconds, even sooner at higher RPMs such as when I kick it directly down to 3rd (bypassing unlocked 4th).
    I have tried swapping transmission fluids twice, and the fluid level is definitely correct. I also replaced the pickup screen, but the old one was fine, and the fluid has always looked good for the vehicle's age and mileage. Shifts are firm and there are zero issues aside from the terrible noise. It has occurred consistently for two years, and occurs only at the moment the torque converter unlocks.
    My plan is to keep ignoring it, but if anybody else has solved this problem, I'd love to know.
  2. zzyzzx
    15,276
    1,246
    Have you checked the motor and transmission mounts?
  3. steve60tuesday
    50
    23
    18
    Yes, the lower ones are brand new, and the upper ones were removed and inspected last week. I have also performed the TSB regarding the lower support brace, enlarging its mounting holes, and reinstalling it with overpriced bushings.
    It sounds like cavitation within the torque converter to me. But also, I'm a certifiable idiot with zero experience identifying the sound of cavitation, much less in a torque converter. It also sounds like a dirt bike or a wood chipper, but I can rule those out based on visual inspection.
    I do appreciate the assistance in troubleshooting though!
  4. steve60tuesday
    50
    23
    18
    Update: the tea leaves now point to this being a crankwalk issue. My crank position sensor recently failed due to being ground down by the flywheel.
