Unclal said:
When you asked how I checked the levels, I got out the book and read the proper way. I have added some fluid now I will try it out if we get a cool morning again. I hope that's what it is. I will have to admit to stupidity but at least it won't cost me much.
Thankx for the links I have them on file just in case.
I feel so foolish. Duh
Al
OK, so if I understand you correctly, you looked up the proper way to check the fluid level (as in with the car warmed up and running after going through all the gears), then found the fluid level to be low. after saying
D-oh!, you added some fluid, and now you feel foolish because that was probably it and it was so easy to fix. Correct?
As stupid as it sounds, it's actually quite common. Seriously. We get these threads all the time.
