Australian Ford Laser KH/KF TX3 Conversion | Page 3 | Ford Escort Owners Association (FEOA)
Discussion in 'Exterior Modifications' started by jay92gt, May 17, 2005.
  1. pinky
    pinky Guest
    20
    hate to get off topic but just reel quik is that a protege gtx bumper? and how was it to mount on ur scort?
  2. Dave94LX
    Dave94LX FEOA Donator
    5,787
    238
    Under the Stairs
    no, it is the protege/familia GTR bumper. You can either get the protege support, or trim down a stock escort bumper to act as a support for this bumper. I had a GTR bumper on my blue car a few years back, and I had a trimmed down escort bumper as a support. The bumper slides on, and then you bolt it to the bottom of the fenders. It lines up pretty well:
    [​IMG]
    [​IMG]
  3. pinky
    pinky Guest
    20
    im assuming im also guna need tracer headlights as well. does the plain jane protege lx bumper bolt on just the same? (sorry if it seems like a stupid question)
  4. Dave94LX
    5,787
    238
    Under the Stairs
    I have seen a few scorts with the protege front bumper, and I am assuming that it mounts the same, but I am not 100% on that. Easiest thing to do is hit up a junk yard and try it.
    As for the headlights, you don't HAVE to use the tracer lights, but it makes the front end look a little more lined up.
  5. pinky
    pinky Guest
    20
    thanx alot :)
  6. Dave94LX
    5,787
    238
    Under the Stairs
  7. adrock457
    adrock457 New Member
    13
    Cincinnati, Ohio
    Nothing like being late to the party! Skuce, are you swapping the headlights for a gain in the performance of your headlights, beyond the fact they use H4 bulbs and not 9004, are those better at light projection, or are you just doing this for the look? I have looked high and low for aftermarket headlight housings, cause the old stock one's are terrible, if those are better, beyond just the bulb type, than new replacement oem housings, I am interested in doing this myself. I have pollished the old ones on my 96 and they are better but could be MUCH better. Any thoughts?
  8. Skuce
    Skuce FEOA Member
    3,307
    5
    288
    Ontario
    I used the stock GTR bumper core support (rare to find) and it bolts up...IF....you remove the one stock mount location on the left side of the car. It's 2 bolts. It's just in the way.
    So the bumper is held on by 5 nuts on the core support studs....and 2 screws in the fender corners.
    Probably would be good to get the plastic fittings off a 3rd gen Escort or a Protege. The escort has the metal holes already there from the factory...just no insert to screw into.
  9. Skuce
    Skuce FEOA Member
    3,307
    5
    288
    Ontario
    The Aussie headlights are generally a "clearer" headlight than the North American ones. That means they used less fluting inside the lens.
    There may be some gain since the headlights do have something similar to a cutoff that modern headlights have....but it's not anything huge to write home about.
    It being an H4 does make it easier to convert it over to an HID system (ONLY IF you use a mechanically shrouded High-Low HID system).
  10. 1992tracerlts
    1992tracerlts New Member
    742
    North Dakota
    bumping old thread.
    Any updates skuce? You still working on this?
  11. dwarfmarine
    dwarfmarine New Member
    5
    hey fellas.. just so you know, the Laser bumper available on ozeparts or corksport does not incorporate the lower grey lip that is seen on the pictures that were posted. these are very rarely available as a separate item... not found at many AUS wreckers, and if you do find one, it will more than likely be from a member on FordLaser.com
  12. Dave94LX
    5,787
    238
    Under the Stairs
    hehehe, I actually used to own one of the gray TX3 front lips. I had picked it up from Corksport years ago. I just never got around to installing it, and ended up selling it. It was 2 pieces, and had mounting tabs the whole way accross it.
  13. Skuce
    Skuce FEOA Member
    3,307
    5
    288
    Ontario
    I think I own that one that you're talking about Dave. lol. It's in the basement on the shelf right now.
  14. Dave94LX
    5,787
    238
    Under the Stairs
    yep, I believe you are correct
  15. FordEscorter
    FordEscorter New Member
    508
    i woud like to add the laser headlights and grille to my car. what all would i have to do to make it fit?
  16. Skuce
    Skuce FEOA Member
    3,307
    5
    288
    Ontario
    -Laser KH or KF Headlights (Pick which style you like...OZparts)
    -Laser KH or KF Grille (matching headlight shape...OZparts)
    -Laser KH/KF Corners (stock or aftermarket clear...Escort do not fit...OZparts)
    -Laser KH/KF "City Light" sockets (or there will be an empty hole in the back of the headlights) - have to get these from a wrecked Laser
    -Laser KH/KF Inner steel headlight brackets (under the grill and bolts to the rad support) or fab your own. (Metal Fab or Wrecked Laser)
    -H4 Headlight harness or 9004-to-H4 conversion harness (ebay)
    -Modify Bottom headlight bolt location on stock fenders (cut/welding)
    -Bumper with no "Hump" in the center (Tracer or 323/Pro or Aftermarket)
    -No A/C - piping sits behind diver side headlight location
    Pick One of the Two Following choices:
    -Move Rad over ~1"-2" towards passenger side (to clear drivers headlight socket) by modifying upper and lower rad brackets (welding)
    "or"
    -Swap in 90-94 323/Protege Rad support and Radiator (this is what the Lasers used as Stock parts) (welding)
    -Use 90-94 323/Protege Upper and Lower Rad Hoses
    That's the total list to do a "Good" job of the swap
    See page 1 of this thread for Pics of the issues that need to be addressed.
  17. Skuce
    Skuce FEOA Member
    3,307
    5
    288
    Ontario
    Has anyone else done this yet? I can't be the only guy that got the stuff.
  18. twisted95
    twisted95 FEOA Donator
    537
    30
    178
    charleston
    where can i get the lower part of the laser bumper?
  19. RcCarRacer1992
    RcCarRacer1992 FEOA Member
    491
    10
    168
    I like the look of this minus the stupid paint job and the front bumper. but grille and headlights look good! :)
    [​IMG]
  20. Escort LXR
    Escort LXR Customizer
    406
    115
    103
    COLORADO
