ok, as a few of you may know, I bought an Asus EeePC 900 recently. It came stock with 900Mhz processor, 1GB RAM, and 16GB SSD. I have since upgraded to 2GB RAM, and slapped a 32GB SDHC card in the SD slot. The problem that I have run into is that the SSD that came with this computer is very slow. Most of the complaints about this computer are related to the slow SSD speed.
Soooo... I found a PCIe CF adapter for cheap on eBay, which I decided to pick up. I also purchased a 16GB CF card. I used Acronia True Image to copy the contents of the SSD over to the CF card, which seems to have worked. When I swapped the CF card in though, I get an error. It will not boot off the CF card for some reason. I have seen a few tricks online requiring to load Linux, and then load XP over top of it, but I do not want to do that. I would like to use the imaged copy of XP that is on the CF card if at all possible.
Anyone have any knowledge of this?
