1 - 5 of 5 Posts
Thats not a lot of power!
Xenons are the same as normal bulbs...except they are tinted and are gas filled.
Glow pedal are EL material...take about the same power as a big LED.
Neon....High voltage...low power
A 600w amp is probably on pushing about 300 most of the time anyway...not a lot there...if you´re worried about that one...get a cap.
So your batt and alternator are fine.
On my bulbs, the watt rating is higher than regular bulbs. The watts on my
APC headlights are 100/80. I haven´t installed them yet because i heard that bulbs with that high of wattage can destroy your electrical system. They say you need to wire a new harness first. Is this true?
1 - 5 of 5 Posts
