Anyone remove the rear glass form a latter EXP ? | Ford Escort Owners Association (FEOA)
Discussion in '1st Gen 1981-1990 CVH' started by austin86, Aug 27, 2019.
  1. austin86
    588
    143
    58
    Ohio
    You know the big old bubble glass window on the rear hatch.
    Has anyone removed it here? I'm wondering how did it go?
  2. JOEG5982
    JOEG5982 FEOA Member
    361
    79
    178
    Be very careful! It is a Butyl adhesive so easier than with Urethane, but you still need to be extremely careful as it will shatter with the slightest mistake.
    austin86 likes this.
  3. austin86
    588
    143
    58
    Ohio
    That was my thought. I'm going to replace it with lexan so if it brakes it not the end of the word. I just don't want it to brake wile removing it then be left with the clean up.
  4. 1982 EXPert
    1982 EXPert FEOA Member
    56
    37
    28
    Have you replaced it yet?
    I've done the ones on 82-83s (notchback), it's not easy. I can't imagine what doing the bubbleback would be like, it's gotta be hard.....
    Ford presses the glass onto the opening flange too hard making the sealant too thin to fit a remover into. If that doesn't work it's best to break the window and then install a new one, any glass shop can make a new one somewhere between $200-$350: which is still cheaper than having one of the corner windows made ($370) if that says something.
    Your biggest issue will be figuring out where to put it once it's off, it needs to sit upside down on something soft that can distribute the weight (like a mattress). Sitting on upside down on a table or something can crack/bust it right in the middle, setting it rightside up anywhere will break it. They're only strong when installed :/
