Anyone know how to install push button start? | Ford Escort Owners Association (FEOA)
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by 1999dohczx2, Nov 28, 2007.
  1. 1999dohczx2
    1999dohczx2 Guest
    5
    Does anyone have a write up on how to install a push button start for a 1999 ZX2 with manual transmission? I'm thinking this will be easy considering I want to continue to use my key for ignition also.
    Thanks for the help.
  2. lessthanchad
    lessthanchad Guest
    122
    well i know how to install it. but i dont know if it will work for the manual. and you could still use key. but it would serve no funtion but to turn on the electrical. so let me know if you want the write up.
  3. boostedzx2
    boostedzx2 Guest
    17
    I would really think twice about using it on a manual .. god forbid you leave that baby in gear .. good bye
  4. BrianG
    BrianG New Member
    233
    can you do a write up?
  5. lessthanchad
    lessthanchad Guest
    122
    yea but it might be awhile until i can get it up. just got a hernia at work and hafta get surgery so it might be a little bit.
  6. Mylilsescort
    Mylilsescort Guest
    7
    I also would like to see something on this. I am a firefighter, and i know its tuff on my car to take off reving it when its 20 degrees outside and has no time to warm up at all. I figured giving it 2 min would help some so a remote start would be nice. O and what would happen if you left it in gear? try to take off on ya?
  7. lessthanchad
    lessthanchad Guest
    122
    With the push button ignition (or flip switch) in cold weather you might have some trouble with it. So you will want to install an inline fuse or it will blow out your cabin fuse (lights, radio, ignition). I don't know if it will actually start when in gear. I doubt it unless its in 2nd or 1st i suppose. But then again you should always have your parking brake on anyways. But I will have the full write up after i heal up from surgery tomorrow. SO if you can be patient i can get you a great setup/
  8. BrianG
    BrianG New Member
    233
    hope the surgery went okay bro, but any ideas when the write up will be posted?
