Anybody ever replace an outer Tie Rod End grease boot? | Ford Escort Owners Association (FEOA)
Discussion in 'Suspension' started by mmahamm, Feb 6, 2008.
  1. mmahamm
    mmahamm New Member
    110
    I replaced the right outer tie rod end, which had a torn boot, with a new one. The left one, meanwhile, has its boot still intact, but the Tie Rod End is loose. I would like to re-use the right one, because it is nice and tight. Last night, I removed the boot, as much as I could, but it appears to be held on by the rim underneath. I cut it away with a razor blade, but the top of the boot is still under that rim (kind of looks like the edge of a soup can), and cleaned the Tie Rod End with Brake Parts Cleaner. It is beautiful, clean, and dry, but without a boot.
    Is there any way to put a new boot on this sucker, or should I just punt and get a new Outer Tie Rod End? I figure if I can live with just a boot, I can save about $25.
    Any experience out there?
  2. Abarthel
    Abarthel New Member
    1,849
    I personally would just replace it. easier in the long run from my point.
  3. ei1429
    ei1429 Guest
    6
    Headake
    Your better off just replacing it, trust me it will come back to haunt you!
  4. DeathSlinger00
    DeathSlinger00 FEOA Member
    2,596
    288
    Elyria, OH
    Re: Headake
    ^^^ what he said. ;)
    besides, you're already in there anyway, it'll probably just be faster to replace the tie rod end than the friggin' boot.
