Amp/sub problem | Ford Escort Owners Association (FEOA)
Amp/sub problem
Discussion in 'ICE (In Car Entertainment)' started by larrythecar, Jul 31, 2007.
  1. larrythecar
    larrythecar Guest
    36
    ok so heres the deal
    i just got a clarion amp and rockford sub so i decided i was gonna hook them up today
    i just spent about four hours hooking up all the wires and i am not getting sound or power to the amp
    could it be a bad amp?battery?
  2. zx24u
    zx24u Guest
    40
    make sure you have a fuse in the wire first...then make sure you positive and neg. speaker wire is hooked up right..
  3. larrythecar
    larrythecar Guest
    36
    fuse is in
    wire is on the positive
    speaker wire is in the sub correctly
    the only question is, there are two outputs on the amp "speaker A" "speaker B" does it matter which one i use
    the power light doesnt come on the amp so its not getting power..
    could not properly grounding make it fail to recieve power?
  4. mtlhead
    mtlhead Guest
    311
    where are you grounding it to
    wheres the remote wire coming from?
  5. larrythecar
    larrythecar Guest
    36
    problem sorted out...
    thank you both
  6. mtlhead
    mtlhead Guest
    311
    what did it end up being?
  7. bradsescort
    bradsescort FEOA Donator
    1,902
    298
    in the pic above Pensacola, FL
    i bet he forgot to hookup the remote wire.. simple mistake and my first sub installation i did, this is what i forgot too.. basically a wire specifically from the headunit to the amp to tell it when to kick on..
  8. larrythecar
    larrythecar Guest
    36
    i had the remote wire hooked into the wrong blue wire in the deck... so i found another one tucked inside all the wires and that turned out to be it
  9. citrate
    citrate Guest
    90
    ahh yes the antenna wire vs amp remote mixup lol
