1 - 7 of 7 Posts
okay, it's been about two days since my system has been put in, and now im noticing another problem with my car (to add to the list).
it seems that only when i am running at ONLY (or very near) 1,500rpms i hear a noise coming from the engine compartment that can only be described as the noise of an old, and maybe dying refridgerator motor makes: kind of a scratching, grinding noise.
now i know that alternators tend to die sooner becuase of the installation of loud speaker and amplification equipment.
so am i right, is is the alternator?
and if it is, will it get worse and what are my symptoms going to consist of when it gets worse? :lol:
thanks
dan
I dont know if it's that but i changed my alternator, and after a while if it's new you have to get your belt tighten because the belt streches after a while. Also, even if you have a new alternator doesn't mean it's ok, mine was 2 weeks old and it died on me.
hope you undertand. Good luck
On the subject of belts (I don't mean to hijack a post). This is happening more and more frequently, when I start my car I get a horrible squealing sound from the engine bay. I have to rev my engine to about 3 or 4 grand before it stops. Is this the timing belt? If so, will it be relatively easy to replace?
I've had this happen several times. Now I only get my alternators from NAPA or the junk yard. Places like Pep Boys, Autozone, etc. sell alternators that last from 30 seconds to about 1 month.
Ben there, done that like 7 times.
my alternator used to squeak when i first would start it up after it would sit for more than 6hrs. but then once i got garage privilages, i noticed that it slowly went away. for my case; it was moisture buildup, but by the sound of it, yours seems a bit worse than what i had... :lol:
1 - 7 of 7 Posts
