1 - 15 of 15 Posts
hey guys its fricken cold here now and i was noticing that my alternator seems to be going, or thats what i think
the only reason i think this is because when i turn on my car to warm it up, and the heater is on 3/4 it barely blows air its really really quiet, then if i give it a quick rev, the heater will speed up to its normal speed and stay like that
now this may be a blower problem or maybe thermostat (doubt it) but i dunno have any of you guys experienced this before
and i replaced my battery with a pimped one last winter so i doubt its battery
When my alternator went out the first thing I noticed was my headlights would dim at higher RPMs, because the alternator wasn't recharging the battery enough to power both the engine and the lights (I suppose) and the stereo was real quiet unless you kept it down by like 2k, which seems to be the opposite of what you're describing.
I found when mine was dieing the headlights would dim when my stereo was loud. Crank up the tunes during idle, and see if your headlights dim a lot... unless u have a good system, cause then they're gonna dim unless u got a cap. U can also go to most local shops and they'll do a load test for ya.
Please get your alernator checked right away. Often, people let it go too long and the battery carries the load, discharging it so completely that it won't charge up fully after. Before you know it, the battery is dead too. More cost.
Usually, an alternator starting to go can be noticed by dimmed interior lighting and wonky gauge performance.
hmmmm it seems that i dont really have symptoms of a bad alternator, so what does a laggy heater mean?? going blower
and i got the battery from napa tons of cold cranking amps more then i need but like top quality one, i dont know the specifics cuz my friend got it for me at cost
Is it just the fan that's having the problems??? Like as it heats up... does it begin to work better??? I had that in something.... not sure what, but I found that oiling the bearing worked... not sure whether it was a car fan, computer fan, etc... but the fan sucked till it got warm, or till I oiled it.
Discussion Starter · #9 ·
what fan did you oil??? the rad fan, or like the blower for the heater
im gonna use lithium grease if i do this
oh and when the heater first starts up it makes a bad sound like a bearing is shot or something but then gets quiet after like 20 seconds
I still don't know what a pipmed battery is.
I'm also guessing that you might have the same problem that I did with the blower once where it got underwater because snow got into the vent intake and flooded it. If you look in the area between yor windshield and the hood there is a cavity where water runs into. It drains through holes in the fenders. When those fender holes get clogged, the water abcks up until it overflows into the air intake for the heating and air conditioning system. Once that happens the water runs down into the blower, and since the Escort has this plastic cover on it, it retains the water and eventually ruins the blower.
In my case I caught it in time and dried out the blower motor and then took the plastic cover and drilled a drain hole in it then reinstalled everything.
If the blower motor chirps at low speeds then that's normal for this and some other Fords, there is a TSB on it and you have to replace the motor with a new one to get rid of the noise (not worth it IMO).
I suspect that this is what happenned to you too. At least check it out and clean out the fender holes and then check to make sure that that area drains properly. This affects all cars over time (at least anyplace where you get leaves and stuff accumulating there, think if it as a small composting heap in your car).
Discussion Starter · #14 ·
you wanna take a picture of the hole you drilled i bet money this is my problem , also a pimped battery is well a battery that pimps da hoes to do its shiat
hahah i dunno no its just a high quality battery all i know is my battery died and i called up my friend said get me a battery a really good one and he got it at cost and i got it in the car so it would run
didnt really care about what series etc. but its a napa like i dunno how there series work but second from highest
Discussion Starter · #15 ·
ok so i had something happen, i started my car and the heater lagged as usual and when i hit the gas the heater speed up and my interior lights got brighter
if that helps
but im going to try and get it tested just i have no time , plus shops are busy with everone elses car breaking down in the winter
1 - 15 of 15 Posts
